Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
Thread: Connect Nav Plus Navigation System
  1. #41
    Re: Connect Nav Plus Navigation System
    Maybe you should dl the latest versions
    Navteq Connect Nav + Europe 2010-2011
  2. #42
    Jan 2012
    I have downloaded Benelux and burn it as iso file on cd but when i put it in my alfa 147 (2002) it says no map available help me please
  3. #43
    Jan 2012
    BtW i'm use windows seven en burned with windows seven iso burner and my cd is "CD-R" merk of cd is "imation"
  4. #44
    What is the contents of your cd after burning?
    How many file/folders
  5. #45
    w.0
    w.0 is offline
    Jan 2012
    Hello, I have a Fiat Bravo with connect nav + (G2). I've only the French map, and I would like the map of Europe. Where can I find it?
  6. #46
    w.0
    w.0 is offline
    Jan 2012
  7. #47
    thespikie is offline Lance Corporal
    Apr 2012
    I updated my nav + but would like to downgrade back. (AR 159 2006)
    But have the firmware :-(
    Greetings
  8. #48
    Apr 2012
    Greetings
  9. #49
    Apr 2012
    I updated my nav+ but would like to downgrade back. (AR 159 2006)
    But have not the firmware :-(
    Greetings
  10. #50
    Apr 2012
    Is it possible to downgrade the Firmware from version 12.3 to 11.5 ?
    If it is, where is it then possible to get the Firmware verion 11.5 ?
    Thanks in advance
