Results 1 to 10 of 14
Thread: NIT G2 connect
    senna75 is offline Second Lieutenant
    273
    68
    NIT G2 connect
    Hi. Looking Lancia phedra G2 NIT Eastern Europe CD! Thanks
    Re: NIT G2 connect
    The G2 system is identical to the Opel Siemens=VDO NCDR/NCDC system
    There is no Eaastern European coverage for this system and since it was discontinues in 2003 it is unlikely that there will be coverage in the future
    273
    68
    Re: NIT G2 connect
    Hi Gazo. This will be the 2006 Lancia auto phedra! This is not RT3?
    Re: NIT G2 connect
    No that is not RT3 and RT3 was only fitted in Citroen and Peugeot
    273
    68
    Re: NIT G2 connect
    Thanks Gazo.
    ricci13 is offline Sergeant
    46
    Re: NIT G2 connect
    u can put rt3 maps on lancia phedra...trust me
    Re: NIT G2 connect
    I know, but the fact is that a G2 is not identical to an RT3 navigation
    It only uses the same map cd's but the system software is different
    273
    68
    Re: NIT G2 connect
    Now, the RT3 is good?
    sucro's Avatar
    sucro is offline Staff Sergeant
    91
    21
    Re: NIT G2 connect
    it's ok, you can use rt3 maps.
    barton631 is offline Corporal
    24
    Re: NIT G2 connect
    is somewhere link to the software for G2??? thx
