22Likes
27th August 2011, 12:12
#11
Re: iGO My Way for Android (800x480) (480x320) (320x240)
Can I have Europe Countries Maps not in Pack... In Split Links...
Thanks In Advance ...
31st August 2011, 22:56
#12
1st September 2011, 01:07
#13
im used android tablet with honeycomb, resolution 1024x600, its posibble to me to use this IGO 800x480? thank you
8th September 2011, 11:14
#14
Re: iGO My Way for Android 8.4.3.179971 (800x480) (480x320) (320x240) + All Maps
do you have map special for indonesia ?
10th September 2011, 13:58
#15
Installed Igo on Samsung Galaxy s2. At first all ok with the program, but when I started to install maps a message come up: "Missing or incomplete folder: Android_Amigo_Engine_Multilang. lyc:/data/data/com.navngo.igo.javaclient/license/Android_Amigo_Engine_Multilang.lyc (No such file or directory)"
Since that it does not start up at all...
Tried to reinstall, but all same... Any idea what is wrong?
Thanks in advance!
10th September 2011, 16:09
#16
Well it's obviously complaining about the lack of a license, and the data structure it's referring to is setup by the installation of the apk file. If I were you, I'd reinstall the apk file.
10th September 2011, 17:53
#17
I tried... Uninstalled, deleted all, reloaded/installed, but nothing...
11th September 2011, 12:37
#18
I had some problems getting this version to run also. If I knew what resolution you were looking for I'd pass you a link, but in the absence of that, I would suggest that you try IGO My Way 8.4.2.139242 for Android. For all practical purposes, it's the same as 8.4.3.179971. I worked for me, when I couldn't get 8.4.3.179971 to work. If you need a different resolution post. This is 320X480.
The Following User Says Thank You to dohcacr For This Useful Post:
11th September 2011, 17:57
#19
Hi, i need a 480x800 for Galaxy S2. Tahnk you.
11th September 2011, 18:50
#20
