Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 127
Like Tree5Likes
Thread: Sygic GPS Navigation v12.1.3
  1. #11
    Nov 2011
    re: Sygic GPS Navigation v12.1.3
    How to get sygic
    1. Download Sygic in PlayMarket and open App Download Database+You Map(If you can't download map you can you SygicDL to download map and pate it in ti folder sygic in SDCard
    2. change Name folder Sygic to Sygics
    3. unstall app sygic
    4. Download Sygic_12.1.3.CK.apk Sygic_12.1.3.CK.apk and install
    5. change Name folder Sygics to Sygic
    6. Open App Sygic
    Usertje likes this.
  2. The Following 5 Users Say Thank You to punkgalz For This Useful Post:
  3. #12
    Dec 2011
    And for those who have already purchased a nation? Will benefit of the maps if downloaded separately?
    edit: I Reply to myself: Yes, just tried it now!
    rth likes this.
  4. #13
    thank you for upload, it works on galaxy s3
  5. #14
    Quote Originally Posted by ducina View Post
    yes, it is working as well on my galaxy s3 jb (4.1.1) - i can confirm.
  6. #15
    cefru is offline Lance Corporal
    15
    Failure on the first point. I can not download the map without pay. Where is SygicDL for this version?
  7. #16
    Quote Originally Posted by cefru View Post
    In this case, your trial period has expired (I'm sure you have tested the 12.1 sygic version some time ago. In your case you have to search for the 2012.3 maps int the internet. Once you have downloaded your desired map, copy the files to the Sygic folder on SDcard.
    PS: Yes, there is NO Map download as it was in 11.2.6. The map download is within the 12.1.3 Sygic (under the menu MySygic). But as I wrote: Once your trial perios expired you have no download option anymore ...
  8. The Following User Says Thank You to rorob For This Useful Post:
  9. #17
    15
    Thanks, I'll find a map to test this version.
  10. #18
    If you can't find your desired map, send me a PM. I have downloaded some european maps - maybe I can help ;-)
  11. #19
    Jan 2012
    ok on galaxy note
  12. #20
    Dec 2011
    working fine on my galaxy s3
