are you sure that this will still work after the expiration of the trial period?
Sygic GPS Navigation v12.1.3 Cracked APK Android
Requirements: For Android version 2.1 and higher, supports App2SD
Overview: Premium turn-by-turn GPS navigation app. Sygic is the offline voice guided GPS navigation app trusted by millions of customers around the globe. It's packed with TomTom maps and a robust set of navigation features. Both app and maps are updated for free. Maps are stored on the phone - no internet needed.
What's new Sygic 12.1.13
NEW TomTom HD Traffic available at Sygic | GPS navigation for smart phones
(If you’ve been using our traffic, TomTom data is already switched on for you)
NEW MAPS with updated road coverage!
1. Connect to Wi-Fi
2. Visit menu – My Sygic – Manage Maps
3. Tap to select maps you wish to update
4. All old maps will be removed automatically
NEW Cyprus map added to packages Europe & America & Southeast Asia & Africa, Europe & Russia, Europe and Eastern Europe.
Sygic. We listen.
How to:
1. Install Sygic trial from this link :
http://ul.to/235pn0yj
http://depositfiles.com/files/oo9z96v2o
http://turbobit.net/jmfq1bc4fbb0.html
2. Active sygic as trial and downloads your needed maps.
3. Now using Explorer rename "Sygic" folder on your sdcard to "Sygics".
4. Uninstall Sygic trial App from your phone.
5. Download Sygic_12.1.3.CK.apk from here :
http://ul.to/bzrf1r01
http://turbobit.net/zf89odgbd62i.html
http://depositfiles.com/files/8oye38kn7
and install
6. Now change again folder "sygics" to "Sygic" (back to origional name)
7. Open App Sygic.
Thanks to: punkgalz
More Info :
https://play.google.com/store/apps/d...gic.aura&hl=en
How to check if you have installed this properly:
1.) Using your favorite file manager, navigate to /data/data/com.sygic.aura/files/
2.) Open your .flurryagent file as "View as Text File"
3.) Search for license lifetime
100% Working Prove :
http://www.mobilephonetalk.com/showt...-v12-1-3/page3
Thanks for sharing this. One question : is it possible to still load maps after this process (if I forget to load one or if I suddently plan to go abroad) ?
Any TTS for this please
Short answer is NO so download all the maps you want while in trial mode. I had to revert back to trial mode to download the maps i forgot before trial mode was up, then reinstalled the crack again.
There are TTS voices. You will have to download them yourself from the My Sygic section in the main menu. They are not installed by default. I was also able to download new maps from the My Sygic section with the cracked apk. I did not have to revert to the trial apk.
"A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty."
- Sir Winston Churchill
what if I wipe phone and flash again
could I dwld again with another gmail acc
