What's new
NEW TomTom HD Traffic available at Sygic | GPS navigation for smart phones
(If you’ve been using our traffic, TomTom data is already switched on for you)
NEW MAPS with updated road coverage!
1. Connect to Wi-Fi
2. Visit menu – My Sygic – Manage Maps
3. Tap to select maps you wish to update
4. All old maps will be removed automatically
NEW Cyprus map added to packages Europe&America&Southeast Asia&Africa, Europe&Russia, Europe and Eastern Europe.
Sygic. We listen.
Download
Part 1 http://dl-1.one2up.com/onetwo/conten...491a5e43d0.rar
Part 2 http://dl-13.one2up.com/onetwo/conte...22ee05e15f.rar
Part 3 http://dl-15.one2up.com/onetwo/conte...8ca6530f6e.rar
Part 4 http://dl-6.one2up.com/onetwo/conten...25564e1d18.rar
Or only APK
Sygic_12.1.3.CK.apk
How to
Extract files and move sygic folder to SDcard and install Sygic_12.1.3.CK.apk(you can see APK in sygic folder )
Note
it s a Map Thai if You want another Map you can use SygicDL to download map you want
Or
1. Download Sygic in PlayMarket and open App Download Database+You Map(If you can't download map you can you SygicDL to download map and pate it in ti folder sygic in SDCard
2. change Name folder Sygic to Sygics
3. unstall app sygic
4. Download Sygic_12.1.3.CK.apk http://www.mediafire.com/?a47hnqki3523286 and install
5. change Name folder Sygics to Sygic
6. Open App Sygic
Link doesn't work![]()
Can you upload the sygic_12.1.3.ck.apk file only so that we dont have to download everything that we do not use.
Thanks.
"A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty."
- Sir Winston Churchill
Hi...
But someone has tried it? It 's really cracked?
Hi All,
Please download the Sygic 12.1.3 Trial vesion from market and then install first after that please you download all the map that you want
after completed all please uninstall the trial version and back to install the crack version (Sygic_12.1.3.CK.apk) and try to run application that all is work fine.
(activated was done).
Thanks,
PUNGALZ- Can You upload it to a faster hosting server??? Otherwise this post is useless...
