... "smiling".... the downloads from sygic downloader are old maps named as 2013.01, but in fact those maps are from 2010 and 2011
Today Sunday afternoon I will upload the new maps version 2012.09
Look in this tread later: android-gps-software-tomtom-sygic-igo-navigon
Have fun![]()
After doing the steps, the app keeps telling: buy application, or continue free trail.
Will the application stil work after the trail is expired?
You have to install the sygic v.12.2.0 trial to download data-content.
Then use those download to maps you see around and copy it to your sygic/map folder
Rename your "sygic" folder to "sygic_1"
Uninstall Sygic v.12.2.0 trial
Install then Sygic v.12.2.0 full
Don't run yet, rename the folder "sygic_1" back to "sygic"
Then run your sygic, and just drive carefull
Have fun
PS: you can also read all about it here, and download the new maps v. 2012.09 to
Look here: Android GPS software TomTom, Sygic, iGO, Navigon
Hi... Have also upload all the new maps v. 2012.09 from all over the world in separated regions and country to
have fun![]()
I got locked out by Sygic. It doesn't work now. It was working since I installed it 3 days ago and now it's not working. There must be a hidden file that preventing me from reinstalling. What I did this morning was to tick "Allow automatic updating" in Google Play and thereafter it is asking for registration.
Uninstalled and deleted all files with "sygic" but still no luck.
"A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty."
- Sir Winston Churchill
@curiou5: similar thing happened to me. i installed a new android and had to make a new google account before i could get 12.2 working.
i have a multi boot htc hd2 so not really a problem but otherwise just try a new google account first.
youve probably guessed by now, but you dont want to auto-update "try-ware" programs![]()
i think i have some combination of old and new maps in 2013.01 folders.
is there any way to tell which version is which, is there some text or bytes in the files that i can check?
Thanks a lot, works good on Galaxy Note
Sygic Navigation v12.2.0 Full
Requirements: Android 2.1+
Overview: Sygic is the offline voice guided GPS navigation app trusted by millions of customers around the globe. It's packed with TomTom maps and a robust set of navigation features. Both app and maps are updated for free. Maps are stored on the phone - no internet needed.
What's new:
- Improved map design
- Three Alternative Routes
- Sharp Curve Warnings
- Junction View
- Notifications for navigation in background
- Avoid street or roadblock easily
- Route cancels automatically when you near your destination
- Lock screen rotation
- Change Font Size in menus
- Favorites and History with more details
To display junctionView add in Maps/content.info the following line:
[PRODUCT:Sygic Eastern Europe]
name=Sygic Eastern Europe
tts=yes
sdk=no
truckAttr=no
premiumPOI=yes
exPostals=no
naviType=pedestrian,car
junctionView=yes
3dContent=yes
cityguides=yes
speedcam=...
maps=...
How to install:
1. Install Sygic 12.2.0 - trial
2. Start the application and downloads resources, etc.
3. Using a file explorer rename folder Sygic to Sygic_1
4. Uninstall Sygic 12.2.0 - trial.
5. Install Sygic 12.2.0 - full
6. Change folder name Sygic_1 back to Sygic.
7. Start Sygic application.
This app has NO advertisements
More Info:
Download Instructions:Code:https://play.google.com/store/apps/details?id=com.sygic.aura
Sygic Navigator Aura All Maps 2012.09
Thanks to: ScorpioPirate
Click the "Thanks" button if you like this post!
