Sygic Navigation 12.2.1 - full
http://i46.tinypic.com/2zzkl0o.gif
How to install:
Method 1:
1. Install Sygic 12.2.1 - trial from here:
link
mirror:
link
2. Start the application and downloads resources, etc.
3. Using a file explorer rename folder Sygic to Sygic_1
4. Uninstall Sygic 12.2.1 - trial.
5. Install Sygic 12.2.1 - full from here:
link
mirror:
link
6. Change folder name Sygic_1 back to Sygic.
7. Start Sygic application.
Method 2:
1. Put on card Sygic folder from this archive:
link
mirror:
link
2. Copy into Sygic/Maps folder desired maps.
3. Install Sygic 12.2.1 - full from here:
link
mirror:
link
4. Start Sygic application.
Passwd: SA#7g21vaRp3dC8W3011
What's new:
- Solved problems with installation on some devices
- Contain further improvements and optimizations
- Improved map design
Obs.
Requires Android 2.0.1 or higher.
Re: Sygic Navigation 12.2.1 - full
I don't have the the real live traffic icon on map screen....does anyone have the file and tell me where it goes?
thankz
:)Thanks a lot. Working perfectly on my Samsung 10.1 and HTC cell. Keep going ;)
Is there any way to download the latest map without using the phone or with using the phone that already used the sygic trial before.
Working good on SGH S2 imported all my poi's, using 2009.09 maps.
Thanks!
Will this work if somebody already had Sygic as trial? You know that Sygic track installation by imei or wi-fi mac. So trick with old version (11.2.6) has to be used...
