Thread: iGo primo, LG Optimus P-500 no signal, resolution problem
    Exclamation iGo primo, LG Optimus P-500 no signal, resolution problem
    I am trying to install iGo Primo on mentioned LG P-500, but there are two problems:
    1, it cannot lock signal from GPS.While old iGo is working perfect, as well as Google Maps, new iGo is showing satellites, but not locking my position.
    I tried versions thin v1.0 and thin v1.1, but no go Does anyone knows what could be wrong?
    2. Phone has resolution of 320x480, but when I install skin for that resolution, right and down parts of the screen are cutted off.I tried to change sys.txt to 455x320, but nothing significant happens.Does anyone have complete sys.txt which is working on Optimus P-500?
    Thank you.
    141
    Re: iGo primo, LG Optimus P-500 no signal, resolution problem
    Try using these data
    480x320
    And here are the sys.txt
    [device]
    type="android"
    [3d]
    usepolyfarroads=0
    [debug]
    skip_eula=1
    show_battery_percent=0
    experimental_features=1
    screenshotsavecameraini=0
    screenshotfilename="\android_linked_root\capture\i mage_%02d.jpg"
    imei=000000000000000
    usenightmode_tunnel=1
    [dynamiccompressor]
    compressor=1
    gain=10
    [feature]
    back_button=1
    contact_poi=0
    [folders]
    linked_root_list="/sdcard2/iGO /sdcard/iGO /sdcard/sd/iGO /sdcard/external_sd/iGO /mnt/sdcard/iGO /mnt/sd/iGO /mnt/iGO /storage/iGO /mnt/sdcard/sd/iGO /mnt/sdcard/external_sd/iGO /mnt/emmc/iGO"
    ; secondary_root_path="iGO"
    has_secondary_root=0
    ; secondary_app="android_linked_root"
    ; user_backup_path="android_linked_root"
    data="android_linked_root"
    [rawdisplay]
    driver=engine
    screnn_xy="480_320:480x320/320x480:fullscreen"
    ;screen_xy="480_320:480x290/320x450"
    [gps]
    location_net=1
    location_gps=1
    accuracy_workaround=1
    background_navigation=1
    [guidancecompressor]
    compressor=1
    config=high
    [interface]
    use_dual_names=0
    skin="ui_android"
    capture_to_jpeg=1
    show_tmc_eventlist=1
    extra_settings=1
    show_minimize=0
    save_checksum=1
    recalc_voice=0
    show_weather=0
    [loading]
    show_statustext=0
    [modules]
    ITMC_STATION_SELECTOR="TMC_STATION_SELECTOR_NULL"
    IFM_STATION_CACHE="DUMMY_TMC_STATION_CACHE"
    [naviextras]
    boot_service_address="http://zippy.naviextras.com/services/index/rest/2/boot"
    [network]
    available=1
    [sound]
    wheelsound=0 ;
    os_volume="255"
    guidance_volume="255"
    alarm_volume="255"
    effect_volume="255"
    csv_voice_enabled="1" ;
    working=1
    dev_channels=2 ;
    dev_bits=16
    dev_smp_rate=48000
    dev_buffer_size=9216
    [tmc]
    source="gnse"
    internal_tmc_name="gnse"
    port="/dev/gnstmc,0"
    [tmc-http]
    start=1
    enabled=1
    servers.size=1
    servers[0].url="http://zippy.naviextras.com/services/tmclite/data/nng-igo-tmc-iphone/0/"
    dt_dl_0=60.0 ;
    dl_dist_0_km=50.0 ;
    [tts]
    automatic_direction_conversion=1
    announce_exit_directions=1
    always_say_road_names=3
    announce_street_name=1
    skip_exit_numbers=1
    tts_buffer=131072
    ttspro_da_voice_enabled=1
    priority="HIGH"
    [google]
    enabled=1
    start=1
    servers.size=1
