MX Mariner - Marine Charts v1.6.74 (build 74)
Requirements: Android 2.3.3 and up
Overview: MX Mariner is a basic mobile marine navigator / chart plotter featuring quilted offline raster marine charts.
Raster marine charts published by NOAA (USA), LINZ (New Zealand) and Brazil Navy are available to install from
within MX Mariner as free, downloadable regions. Once downloaded, each marine chart region is available for use
offline. When online, a road map or satellite image map is alternatively available.
UK chart regions are available for the United Kingdom, Ireland and Channel Islands as in-app purchases. Each UK chart
region in-app purchase gives you 1 year of free chart updates. UK chart regions in MX Mariner are "derived in part from
material obtained from the UK Hydrographic Office".
Please see for more details on offline marine chart regions available for download.
MX Mariner is useful for marine navigation featuring a simple heads up display showing speed and course. You have
the ability to drop waypoints, record tracks and create routes. Routes can be activated and the heads up display will
also show bearing and range to next waypoint below speed and course. All waypoints, tracks and routes can be
backed up as GPX files. GPX files can be imported and exported to other programs.
MX Mariner also has configurable units of measure for bearings, position, speed and distance. Bearings in MX Mariner
can be shown as true or magnetic. Magnetic bearings use the world magnetic model published National Geospatial
Intelligence Agency. Speed and distances can be set to Nautical, Statute or Metric. Position can be set to degrees,
degrees-minutes or degrees-minutes-seconds. Navigators can also choose to use their device internal magnetometer
or gps course to orientate ship on the marine chart. Optionally, heading and course predictor lines can also be shown
on the marine chart. MX Mariner also offers configurable back-light levels suitable for daylight to off-shore night conditions.
What's New :
v1.5 build 74
- Android 5.0 (Lollipop) updates
v1.5 build 72+
- Fix bugs in route and waypoint edit mode
- Post ActiveCaptain reviews
- Fine zoom control
- New street and satellite maps
- Bug fixes
v1.5 build 63+
- Keep screen on options
- Support secondary storage for all API levels
- Improved downloads in adverse network conditions
- Fixed GPX file association
- Marks manager improvements
This app has no advertisements
More Info:
Download Instructions:
MX.Mariner-Marine.Charts_v1…zip (11,67 MB) -
