Results 1 to 1 of 1
Thread: GPS navigation and maps Sygic v16.2.6 FULL
    nyky is online now Major
    Apr 2014
    Requirements: 4.0+
    Overview: Sygic: GPS Navigation & Maps is installed Offline turn-by-turn GPS navigation of the App World for Android powered by TomTom maps. Navigation and maps are installed on the SD card so there is no need for an Internet connection when navigating. Map and app updates are free of charge every three months.
    Maps available ONLY WITH PREMIUM:
    Sygic | Bring Life to map
    New skin is implemented
    [Green areas will come with the new Map Update]
    1. uninstall the previous version and delete the folder Sygic <--- Start clean!
    2. Copy Sygic folder to root out internal or external SD <--- Use by OP
    3. Add maps <----- Use the map downloader from OP.
    Full Europe TomTom maps 2015.12:
    Full Europe Navteq maps 2015.06:
    4. Add Voices
    5. Install APK with patch <--- not open yet!
    6. When you first start Sygic not send email press SKIP.
    7. Have fun!
    This app has no advertising
    Download Instructions: Loans TMPe
    APK patched
    - S *** c shop is not locked, but the valid license file download - useful for TA, only OS maps
    - Advisor, Foursquare, booking, viator is working
    Patched APK + blocked data / Reactivation
    -s c *** store is locked, use APK Original (or downloader SDLER) to download maps, voices, TTS, then install this APK - no longer return to Test status - useful for maps of TA or NT operating system or
    Download s1626c noreactivatetrial useful for maps maps apk
    s1626c_noreactivatetrial_us&hellip;apk (14,18 MB) -
    Base Folder v140160206 (06.04.2016) + ALL VOICES + NT, TA, OS licenses + Speedcams:
    Download basefolder v94 zip (202,73 MB) -
    Original APK
    Download s1626o apk
    s1626o.apk (15,71 MB) -
  2. The Following User Says Thank You to nyky For This Useful Post:
