Results 1 to 1 of 1
Thread: GPS Status & Toolbox v7.2.150 [Pro]
    suyama8 is offline Master Sergeant
    Dec 2013
    Arrow GPS Status & Toolbox v7.2.150 [Pro]
    Requirements: 4.0 and up
    Overview: Displays all the GPS and sensor data you ever were curious about: position and signal strength of satellites, accuracy, speed, acceleration, altitude, bearing, pitch, roll and battery state.
    Tools provided: compass with magnetic and true north, leveling tool, waypoints: mark or share your location and navigate back later using the Radar (especially useful for geocaching, or quick marking your actual position).
    Speed up your GPS location finding: clear or update assistance data (A-GPS) regularly for faster fixes.
    PRO features:
    - show/store/edit/export multiple waypoints and use them on the Radar for navigation.
    - pressure, rotation, temperature, humidity values on the status screen (if supported by the device)
    - background A-GPS downloading
    - widgets
    - removed ads
    - Location: We need this to display your location and allow the app to re-download aGPS data or reset the GPS.
    - Internet: Used to fetch aGPS data and display advertisements and gather anonymous usage statistics.
    - Storage access: needed to export and import your waypoints in GPX/KML format
    - Billing: to support buying a PRO license with in-app purchase
    -- MobiWIA - a cooperation with Andrs Studio --
    What's New
    - FIX: Layout fixes
    - NEW: Updated locations screen
    - NEW: Add new POIs directly on the Locations screen
    - NEW: Reorder POIs on Locations screen by long tapping and dragging
    - ENH: Enhanced Edit location dialog. Better error reporting + clear and set current location buttons.
    - NEW: Categorize your POIs with colors
    - ENH: Added shortcuts on the Sensor test screen for Compass calibration and aGPS download.
    - ENH: Translation updates
    - FIX: Stability fixes
    ● Pro features Unlocked
    More Info:
    Download Instructions:
    GPS Status and Toolbox v7.2…zip (3,07 MB) -
  2. The Following 4 Users Say Thank You to suyama8 For This Useful Post:
