HI,
I burned with a pioneer 112, imgburn on verbatim dvd+r dl at 2,4x speed.
The update starts, but after this, the dvd could not read.
Any tips? Perhaps take a try with verbatim dvd-r dl?
It is not possible
Best thing is to look for another system since no more updates will be issued for this system
HI,
Your best bet is another DVD writer
OK, I will try it with a LG burner.
Yesterday, I tried with a DVD-R DL verbatim, with pioneer 112l, but it doesnt work...
And the Pioneer is fitted with FW 1.09?
The pioneer have the firmware for the audi rns e dvds, I think dangerous brothers?!
Anyway your writer 112l is not on the list. So don't expect it to work
Other writer is recommended.
Do not waste any money on DVD-R DL too expensive and not necessary
How could I see this?
I know, that the pioneer write DVD+R as DVD-ROM with imgburn or alcohol 120%.
On a Pioneer DVD Writer the Booktype is always set vorrectly automatically with any program
Your writer should be a type:
111D Firmware 1.29 seems crucial
112D firmware 1.09
112BK Firmware 112L
If not you will have to find another writer.
Really the best writers for any purpose are those found in the Medion Notebooks and made by TSST
