With this firmware it will not work!
HI,
Pioneer DVR 112L, Firmware 8.25 shows Nero.
Pioneer doesnt set the book type on a DVD+R to DVD-ROM, only by DVD+R DL.
About this, I changed the firmware to this version.
Ok, could I install an other firmware on this drive?
This firmware works great for audi rns e dvds...
The other drive, which I have, is LG GSA H42N.
The you try at your friends or buy another one prior to buying an orignal dvd
So, today, I wil have a try with an LG GSA-H42N.
Thorsten
Burned again, it doesnt work...
And the old nav dvd doesnt work because it could read about the update of the new dvd.
any tipps for me?
how cold tell me please, which burner and which dvd works?
romania in this disc??
http://gpsunderground.com/forum/show...rope-2009-2010
Do you see Romania on this map?
ok sorry!!
Hello guys!
Downloaded map for jeep gc 2006, burned with LG super mulit blue on verbatim DVD+R DL inserted in Car Navigation and voilĂ - worked wonderful!
Read DVD without problem - software update was made - great!
Any idea if a newer map-version will come soon? A few new streets were built in my surrounding and they are not on the map.
Any possibility to render other map data to fit jeep REJ navi???
suggestions?
A new DVD may be published at a later date (could take a few years) but there is absolutely no way to convert data from another platform to this one
