Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Like Tree3Likes
Thread: Chrysler Jeep REJ Europe 2009/2010
    salence and ervahi like this.
    REJ Maps Upgrade
    Hello all,I have a Grand Cherokee with REJ type nav system, I have the Jeep about 6 months, the maps are out of date 2005, I am very anxious to upgrade to the latest 2009/10 maps, I bought an upgrade disk on ebay but it does not work, it did boot up a few times for a short period, so I gave up on it, I recently downloaded (tnx Gazo) the 2009/10 upgrade on rapid share and burned it on to a Verbatim -R DL DVD with imgBurn, but again it brings up the same error message (Error cant read disk)
    So I am wondering how the upgrade works out for others, or am I missing out on something ,is it likely there is a problem with the REJ unit, any help or advice would be greatly apreciated
    Conrod
    Re: REJ Maps Upgrade
    Have you coinsidered the possibility your unit may be faulty?
    Hi Gazo thanks, well I have concidered all possibilitys some say if the origional disk is ok then a recordable disk should run, others say not, I am no expert just a little experience which some say is a dangerous thing, are the recorded disks more liable to show up any misalingment or whateverin the unit, the origional disk works every time
    There are great riscs in using a copy one of which is early and serious wear of the laser.
    Reflection ratio's of copies can be as low as 25% compared to an original and the laser focussing requires higher currents.
    Your problem may be with a dirty, soiled laser lens and/or a very poor copy
    Yes it must the fact that its a copy, as I made a back up of the origional disk and no joy got the same error, but I didnt relise a copy 75% down on the real thing, cleaning the lazer have there and done that, took the whole thing apart and cleaned the lazer with isopropal alcohol, is there any way of knowing for sure the lazer is faulty, where does one get these things fixed, there would be no point in going to the dealer, as his price for a new disk is €430.00
    Thanks again for the help
    wander_hoo is offline Sergeant
    30
    15
    Arrow How to burn Chrysler Jeep REJ Dvd Europe 2009/2010
    Please can anyoane tel me how to burn the Dvd Chrysler Jeep REJ Europe 2009/2010
    Re: How to burn Chrysler Jeep REJ Dvd Europe 2009/2010
    Imgburn
    Booktype DVD-ROM
    low speed
    recommended drive
    Verbatim DVD9
    Verbatim .... DVD+R DL or DVD-R DL?
    I'm having some problems and I don't know if it's the DVD type or the device
    Thanks!!!
    ZELDA-2001 is offline Private
    Anybody know how put the speedcamera on the GPS Jeep ?
    And if it's possible ?
    Thank for your responds....
    Bye
