There is no way to convert the unit
The only solution is to completely replace it which by itself is a major operation since it would seem connection and physical dimensions are not the same and you may also encounter problems with encoding the European unit is a US import
Your best bet would be an after market unit, most of which outwit the poorly designed REJ anyway!
LinkBack URL
About LinkBacks
