Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: JEEP Grand Cherokee EEU maps
  1. #11
    die
    die is offline Sergeant First Class
    122
    Re: Jeep Commander
    Thank you very much for informing me.
    I need only the Eastern Europe region. Can you please tell me the process of creating the hybrid disk?
  2. #12
    miszczu1983 is offline Banned
    77
    Re: Jeep Commander
    Download honda east dvd from this thread
    Honda 2008 Navigation DVD Western and Eastern Europe v3.23
    (while ago the new 3.4 mam was posted by user solidao, but unfortunatelly the thread was deleted).
    Download oryginal mopar dvd image from this thread
    Chrysler Jeep REJ Europe 2009/2010
    Mount both images onto virtual drives, i.e. Daemon tools.
    Open nero and choose new UDF/ISO DVD-ROM.
    Drag all files except U0001_01.BAS and U0001_02.BASfrom MOPAR image into nero, then add two mentioned .bas files from honda image.
    Burn content on good quality DVD+DL or DVD-DL with lowest speed (not necessary, but recommended).
    Check using nero CD/DVD spped if the booktype was set to DVD-ROM.
    P.S. Insted of using nero you may use Imgburn or other software, the important thing is to close DVD and set the booktype to DVD-ROM.
    Instead of using virtual drives you can modify MOPAR image using i.e. PowerIso.
    Good luck.
  3. #13
    die
    122
    Re: Jeep Commander
    Thanks. I have already UltraISO installed on my computer. I suppose I can use it cause it shouldn't be any differences between programs since all I need to do is to make a new image having two files replaced.
  4. #14
    77
    Re: Jeep Commander
    You can use ultraiso.
    My point was that you do not need to create any new image.
  5. #15
    die
    122
    Re: Jeep Commander
    Hi miszczu1983,
    I managed to make the new image.
    However I have some questions:
    - This DVD has upgraded the system (probably to a newer sw) and when I insert the old dvd the system does not accept it anymore. Is it possible to use it again?
    - Another thing is that I could not select an address from Hungary although I can see Hungary on the map but Austria for E.g is ok.
  6. #16
    V8freak is offline Sergeant First Class
    106
    Re: Jeep Commander
    Is there any update for REW (2008) unit?
  7. #17
    77
    Re: Jeep Commander
    die,
    you should have read my post carefully.
    Addres search won't work in EEU countries.
    If you want to use old DVD you need to disconnect battery for a while.
    If you want to use oryginal and hybrid disc simultanously, you need to modify original disc by adding .bas files from honda image, so both discs have same firmware.
    Or you can burn MOPAR 2009 disc.
  8. #18
    die
    122
    Re: Jeep Commander
    Ok, I understand. The thing with the fact that address search is not working in EEU countries is new for me.
    How do I navigate in those countries?
  9. #19
    77
    Re: Jeep Commander
    Destination/point on map.
  10. #20
    die
    122
    Re: Jeep Commander
    Many thanks! you have been a real help.
