Glad I could help you.
I was also trying to do something with address search, but I do not know how to decompress files with ar0 extension...
If you just read all posts in this thread, and there are not many of them, you would find detailed answer.
the poland is on oryginal coverage? or must add to honda 3.23 dvd ?
There is absolutely no coverage for any Eastern European country on the REJ map dvd's
A new version of maps for Honda has been released.
Can I use them for creating another hybrid version for Jeep?
Honda Navigation 3.52
Thank you.
I tried to use .bas files from Honda 3.52 EE to compile hybrid disc to my existing MOPAR AF version - just to use it simultaneously with no software upgrade. Burned to Verbatim (not DL, it has only 4 gigs), book type DVD-ROM and it is not working - still loading....but no error message.
latest version of honda maps which can be used is 3.40.
3.52 won't work unfortunatelly
hi,
thank you guys, i did everything as described, created the hybrid disc, burned it, and inserted into my Jeep.
unfortunately i do not see any eastern europe country on the map. All EU countries are displayed as they shoud, but when I navigate to eastern europe, it's just blank.
what could i have done wrong? should i disconnect the battery and try it again?
Thanks.
Hello
I need to somehow Establish search maps, know how to open soubor.ar0, using EditPad Pro 7 works perfectly ..... please advise
