  • 1 Post By barto30
Thread: Chrysler 300c REJ
    barto30 is offline Paid Member
    33
    Question Chrysler 300c REJ
    hello to all the guys I have a question: I have a Chrysler 300C Rej system, this map is compatible with the system Rej(Chrysler Jeep Europa REJ 2009-2010 AG versión )and the dvd, cd, dvd-dl, etc. .. system is compatible in Rej(dvd 56038650AE )
    Sebmuel likes this.
  2. The Following User Says Thank You to barto30 For This Useful Post:
    Nov 2011
    Re: Chrysler 300c REJ
    asi se hace, todo ok
    Mar 2012
    Oh, it seems that you are having a problem with your Chrysler system. And honestly, I don't get what you are actually asking. Is it time to trade in that beater for a brand new car in Springfield? If so, you need to probably head in to a dealership for some expert advice. I know I wanted help when I finally gave in and went to get my new car. I wanted to have enough choices at the car dealership that I knew I would be satisfied. I was debating between Dodge, Chrysler and Jeep because they are dependable. Luckily, I was able to find a car dealership for me at: Dodge Chrysler Jeep Springfield. Check this out for an inquiry.
