Results 1 to 9 of 9
Thread: Carbon2 Skins for Destinator 9
    joking742's Avatar
    66
    Carbon2 version 3
    Changes from 2.2
    Modified Lane control to make arrows bigger/background blue
    Changed street labels size
    Changed night street draw, colors, labels
    New pop-up maneuver graphics (no backgrounds)
    New Navistrip graphics
    Info added to bottom bar
    image for carbon2.3
    carbon2.3a
    D9 skin (240x240,240x320,240x400,320x240) support
    http://www.megaupload.com/?d=SN5HSM19
    *due to screen size, new navistrip graphics n/a
    carbon2.3b
    D9 skin (400x240,480x234,480x272) support
    http://www.megaupload.com/?d=1K5N51VL
    carbon2.3c
    D9 skin (480x640,640x480,800x480) support
    http://www.megaupload.com/?d=48BK5RRL
    Password for all: joking
    Instructions:
    unrar and place in skin folder
    If this is the only skin you have in the skins folder, rename to All
    To activate skin:
    Use skin changer button to select, should read Carbon2ver3b
    or manually select by opening destinator.ini (located in main
    program directory...contains destinator.exe)
    Locate skin=xxxx change to skin=Carbon2v3a or whatever you renamed
    the folder.
    All skins contain Red and Yellow car grphics
    To change car
    manually select by opening destinator.ini (located in main program directory...contains destinator.exe)
    Locate carcurser=xxxx change to carcurser=Yellow or Red
    Note: If you are using a version of Destinator 9 that does
    not cover the taskbar...This skin may not display correctly.
    The taskbar issue causes compression of the skin and abnormal
    display.
  2. The Following 5 Users Say Thank You to joking742 For This Useful Post:
    Re: Carbon2 Skins for Destinator 9
    Joking742, great work on this nice skin. As you said, it does not display correctly on Destinator 9 that does not cover the taskbar. Where can one find a version of Destinator 9 that does not have this problem?
    Thanks again.
    joking742's Avatar
    66
    Quote Originally Posted by dr8gps View Post
    Thanks again.
    There are versions of D9 that people have modified...I would check "disneyland" (hope you know what this means). From what I've seen, the mods work on some and others don't.
    Joking742, checking some sites and not yet find a good solution to the problem. What does "disneyland" mean for you? Help narrow down the search. Thanks.
    mylnym is offline Sergeant
    30
    "Disneyland" is Substitute a . (dot) for the _ (underscore) in the above URL to get there.
    Thanks for the help. Checking Disneyland!
    thank u man nice skins well done
    merci a toi.
  10. #9
    Apr 2012
    Ola amigo gostaria de saber se tem como você mandar o link da skin carbon para resolução 800x480 pois o link postado anteriormente não esta funcionando mais, grato.
