Thread: Blue Balls Skin for Destinator 9
    joking742's Avatar
    67
    What would happen if you got rid of the navstrip bar and replaced all the icons with funny little blue balls?
    You would have the new "Blue Balls" skin for Destinator 9
    I made this skin to test some ideas...and got a little carried away!
    Features:
    Animated little blue balls (Watch out...they get mad when pressed)
    New Lane display...very visible
    New Pop-up manueaver display (backgrounds removed)
    Background for navstrip bar is gone! (really opens up the map display)
    Better street name size display
    New nighttime colors
    Narrowed horizon display
    Notes:
    To pin sidebar: press the top eye (shows red when pinned)
    Blue Balls
    D9 skin (240x240,240x320,240x400,320x240) support
    http://www.megaupload.com/?d=XQX6WHSY
    *due to screen size, semi transparent navstrip applied
    Blue Balls
    D9 skin (400x240,480x234,480x272) support
    http://www.megaupload.com/?d=ZKVQPD8F
    Blue Balls
    D9 skin (480x640,640x480,800x480) support
    http://www.megaupload.com/?d=4HTSOSVR
    Password: joking
    All skins contain Red and Yellow car grphics
    To change car
    manually select by opening destinator.ini (located in main program directory...contains destinator.exe)
    Locate carcurser=xxxx change to carcurser=Yellow or Red
    Instructions:
    unrar and place in skin folder
    If this is the only skin you have in the skins folder, rename to All
    To activate skin:
    Use skin changer button to select, should read Carbon2ver3b
    or manually select by opening destinator.ini (located in main
    Locate skin=xxxx change to skin=Carbon2v3a or whatever you renamed
    the folder.
    WM Users:
    The Exit/Minimize button on the Nav screen has been deactivated on all skins
    To active: Open you screen size folder in the skin. Open navmain.ini with notepad.
    ;[BtnExit]
    ;position = 282,2,34,34
    ;bitmap=nav_screen_btn_exit REMOVE ;'s in front entrys
    ;[320x240.BtnExit]
    ;position = 190,2,34,34
    Note: If you are using a version of Destinator 9 that does
    not cover the taskbar...This skin may not display correctly.
    The taskbar issue causes compression of the skin on some devices and abnormal
    display.
  2. The Following 2 Users Say Thank You to joking742 For This Useful Post:
    Furry57 is offline Corporal
    Feb 2011
    15
    Re: Blue Balls Skin for Destinator 9
    Hi joking: could you help me get started? do I start with a blank SD card or the original Destinator App & NB.bin and then over write I then tried to load Destinator Version 9.1.21.7 WinCE from this forum I also downloaded Destinator Maps North America - 2009.Q3 (Canada only) are these the newest version I would like to try Blue Balls skin on both Omnitechs 15223& 16878 Thanks in advance.
    Feb 2011
    15
    Well I got it to work just need to fix my odometer reading is way out .5KM=2KM on D9 Blue Balls any help?
    joking742's Avatar
    67
    Quote Originally Posted by Furry57 View Post
    Sorry, haven't been back here in awhile.....Can you explain the problem in more detail. Is it a data issue or skin placement, settings you are using?
