Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 72
Thread: Destinator 8.0.21.275 + Extras
  1. #11
    joking742's Avatar
    66
    Re: Destinator 8.0.21.275 + Extras
    Quote Originally Posted by ST10 View Post
    hi,
    i did all you have described in my moov330 (miopocket r59) but the destinator just does not start.
    The screen goes blue - black and returns to miopocket screen with an error message ""skin not available".
    I have also downloaded a map which was copied to the destinator\MobileNavigator folder.
    destinator configuration read "'MAP_NAME=Midwest (ND SD MN WI IL KS NE IA MO)" eventhough I am trying to use a totally different map.
    in addition i am not expert enough to tamper with the GPSTMC folder.
    any suggestions?
    thank you
    "skin not available" Make sure to download the skin for your screen res. Put it in the "skin" folder and it has to be named "ALL"
    Yes, the config may read something other than your maps...when the SW boots...it will update ask you to select maps.
    I don't know off hand GPS settings for moov330...Anyone know? (really simple just edit .ini file with notepad and save)
  2. #12
    ST10 is offline Private
    Talking Re: Destinator 8.0.21.275 + Extras
    Quote Originally Posted by joking742 View Post
    thank you very much for you reply.
    I think I have downloaded the right skin (my screen is 480X272, so I used your
    480x272
    http://www.megaupload.com/?d=XKKPN6D0
    Forgot to include coreplayer skin....here it is
    http://www.megaupload.com/?d=BW94H5CT
    the path on the card is SD\Destinator\MobileNavigator\Skin\all\480x272.
    the thing is that the program does not open at all, so I can't really choose a map :-)
  3. #13
    joking742's Avatar
    66
    I think you forgot to rename folder (480x272) to all
    copy 480x272 to skins folder and rename folder to all
    should be
    SD/destinator/mobilenavigator/skin/all
  4. #14
    should be
    thank you very much joking, that worked.
    now the second problem is that a window appears that "no map can be found".
    I transfered the respective map files in a folder named map and placed within the folder contain the destinator application, but that didn't worked.
    Then I placed all the map files into the destinator application folder as is (without a "map"folder) but neither that worked at all.
    Any suggestions?
    ST
  5. #15
    joking742's Avatar
    66
    The map folders should be placed in the mobilenavigator directory (same as destinator.exe)
    There should be no subfolders for the individual maps
    If you are using NA...they should be in separte folders (example: midwest, northeast....and usroads)
    Example: you should see folders for lang., voices, skin, midwest,northeast....usroads
    If it asks for a key: see post #2 for destinator maps thread.
  6. #16
    AlexPPC is offline Sergeant
    37
    32
    Yes, I did post this version before the crash. This version (8.1.20.7) was edited by developers to remove TTS. But, has TMC and SafetyCam functions. I re-added SVOX files from version 8.0.20.21.1 to make the TTS work (This is why it shows this version on the about screen).
    I was hoping to develop this version more...but, safetycams D8/D9 are all encrypted, and I could not get TTS to work in other langs...so further development of skins just didn't seem worth it.
    Thank you for fastest reply, joking !
    As I remember many had problems with speedcams in D9. And no success till now.
    In D8 several versions were not able to manage them, but there were just one that can do it.
    And this was because the D8 cams are different that D9 cams. I have now a speedcam file for D8 made by their 'official' rules. I would like to test it. Of course will post results.
    I think the verson that is able to manage speedcams is either 8.0.20.21.1 or 8.1.20.7.
    Moreover I do not care about TTS. I prefer even to not have it as option.
    But I need a skin in order to start the program.
    Are you able to provide me a skin for this version (I published the link in my last post for) for 240x240 device only ?
    Your support will be highly appreciated.
  7. #17
    thank you a million, you are brilliant,
    now it works fine (apart from some "no rural" messages which will be addressed at the destinator maps thread).
    so, if I want to use another map I simply transfer in this folder all the files or it is better to delete the previous ones?
    ST
  8. #18
    joking742's Avatar
    66
    ST
    I'd delete the old maps to save on confusion...but up to you. Newer maps may not always be better for routing, but usually have newer lane info for metro areas.
  9. #19
    Hi again joking,
    I meant to use a map for a totally different area, but I think you are right, it would be better to delete the old ones and avoid confusing.
    The application works now and it shows the right skin and the right map, but no GPS signal is found. Do you think I should change gpstmc.ini to protocol sirf? I am using a mio moov 330.
    Thank you again
  10. #20
    joking742's Avatar
    66
    Hi again joking,
    Thank you again
    If you travel outside your map area it should switch...most map packs contain "some kind of major roads" to connect maps. (although I have seen posts with problems crossing borders)
    I'm not an expert on the moov...I'd set the gpstmc.ini to (below) and see what happens - my best guess
    Port = 2
    BaudRate = 57600
    Protocol = 1
