Thread: IGO Maps - Double din stereo/GPS
    Cool IGO Maps - Double din stereo/GPS
    Hi ! I got the abovmentioned from EBAY.. 7"TFT CAR DVD GPS PLAYER BLUETOOTH TV IPOD MP4 STEREO
    Works ok considering.. However, I tried to load the GPS the other day and it wouldnt get past the IGO loading screen.
    I took the card inside to puter and tried to copy the files to a folder... Everything went well with exception of the saved folder content. Windows said various files were corrupt and wouldnt copy..
    The are
    BJUNC.PRL
    IMGR.PRL
    PIN_V4.sav
    SETTINGS_LOWLEVEL_V1.sav
    I'm assuming that this is the problem that stopped the program from loading.
    I tried doing a disc repair etc, no avail because of these files..
    Question is - can I delete these files or are the necessary ?
    Can I copy the same files back from a donor ?
    Any help is appreciated.
    tonygps's Avatar
    tonygps is offline Command Sergeant Major
    201
    Re: IGO Maps - Double din stereo/GPS
    try the new software version..
    or you can try ask the seller..
    badok245 is offline Sergeant
    59
    You can DELETE the Saved files folder. It will come back later.
    spinrekkids's Avatar
    spinrekkids is offline Private
    when i put SD in i try to load gps. i get an error saying it can't load bmp file. i'm guessing it's resolution.... just need to know how to fix it. any help is greatly appreciated.
    Sorry about that....it's a 7 inch screen original file looks like this
    [rawdisplay]
    screen_x=480
    screen_y=272
    [debug]
    skip_eula=1
    [interface]
    maxzoom2d=6000000
    show_exit=1
    Can i change it to:
    [rawdisplay]
    screen_x=800
    screen_y=480
    [debug]
    skip_eula=1
    [interface]
    maxzoom2d=6000000
    show_exit=1
