Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Problems with the GPS on the AS-6587G radio
  1. #11
    Re: Problems with the GPS on the AS-6587G radio
    Im having a few problems with my Erising 908D i just installed 2 days ago. It came with IGO gps software. When i pressed GPS on the HOME screen it would load up the console which you can then press "Navigation" and it would start IGO. But after the first 5 or so times i used it, it will not work. Now When i press "GPS" on the HOME screen it loads a dark screen with an orange grid in 3d with the words across the middle "Welcome you into the system". No matter what i try it will not load any further from this screen. NOTE: this screen did not ever appear when i pressed GPS the other times. I have tried soft reset and also unplugging the unit completely and reconnecting it, but nothing changes. I am currently waiting a reply from the seller.
    anyone else got any ideas?
    cheers
  2. #12
    here is a link to a picture of the screen it shows after i press "GPS"
    http://img294.imageshack.us/img294/6555/imag0719h.jpg
  3. #13
    kleobis is offline Private
    Gonzalez89.
    I´m from Argentina, I´m new and I´m learning about this.
    I want to gratefull your knowledge and sharing with us.
    I´ve the same problem with time, only with Garmin Mobile Xt. iGo8.XXX, o.k.
    This script, how can I do it, because I don´t use Wolfncu, and where I can found my country index?
    Thanks and regards
    Kleobis
  4. #14
    gonzales89 is offline Private
    @ kleobis,
    It is not important whether or not you use WolfNCU, that was just an example. You must modify the script according to your needs:
    RegWriteDWord("HKLM","Software\Microsoft\Clock","A utoDST","1")
    Run("\StorageCard\TimeCor\szt.exe"," /t-3 /en")
    folder = SystemPath("ScriptPath")
    Run( "\StorageCard\Garmin\RunGMXT\Garmin.exe" )
    - StorageCard can be Storage Card, MMC_Storage (as your GPS calls the memory card)
    - AutoDST can be 1 if you use DST (Daylight Saving Time) or 0 if you don't use DST
    - t-3 is GMT time of Argentina (I hope that is correct) and en is for regional settings in your WinCE Control Panel
    Cheers,
    gonzales89
  5. #15
    Jul 2012
    Hello.I'm from Poland. I have big problems from audiosource as 6587 when strart navi in lcd write "error" I can please send to my oryginal software from this navi. ? Thanks
