Hi everyone.
I have been trying to learn more about what I can do with these type of in-dash units. Here's some more detalis:
It's a 7.0 inch digital(800*480) DVD player with GPS navigation system.
The type of unit can be seen on:
http://www.sharingdigital.com/show.a...name=For%20Kia
where I purchased it from (more images on http://www.cardct.com/kia-navi-dvd/k...ion-dvd-player)
I am still learning all about WINCE 5.0 and unlocking this type of devices. Frankly I am not sure if the unit runs on wince (the hole software allowing access to radio, books, etc...) or it's only the GPS.
I tryed installing (on SD Card) Miopocket V.4 R61 with not much luck since most applications I get errors. As an example either an error message appear or the screen turns black and the main menu reapears.
I tryed previous versions with better results (v.3 R.59). Only a few applications originate erros (I have been reading this forum and I noticed that if I look at the exe files using "Dependency Walker" I can verify the missing dlls required for the programs to run).
In some cases, some applications freeze (with both versions).
When installing Miopocket V.3 it asked me to select my internal flash. I selected NandFlash. Once installed I used explorer.exe to see what could "see". I post some pictures:
Once thing I have noticed is that, after I start Miopocket, radio sound is still on. If I try to view a sample movie, Miopocket does not cut the radio sound as I still hear it. Does anny one experice this?
I tried installing tomtom for WinCe 5.0 devices. Two problems ocurred: 1.- Apparently the TT software can't see where the maps are installed (I moved the maps folder inside SD card/My Documents). After this I get a "iexplorer.exe" error, saying the there is not enough memory.
Also, I tried Navigon MobileNavigator. Funny, after starting the application, a message appears saying that I am running low in battery and the system will shut down within 30 seconds. After this the in-dash DVD car system is frozen and I have to reset the unit.
Any tips for overcoming these limitations?
I thank you in advance.
Regards.
LinkBack URL
About LinkBacks
