Do you know what is the best software to do Garmin Backup? I have Acronis True Image Home 2010, however, it does not show Garmin hard drive. Thanks
You can have multiple subscriptions on you receiver. I thing the ROM in GTM-20 supports about 20.
Behavior in GPS models may differ, in the 7x0/GTM-20 models they are either ALL-ON or ALL-OFF. You can't selectively choose which you are using. The selection is based on a station search by the receiver and whoever it locks onto first is the winner. If it looses reception it will re-search. The choice at any time between TTN and NEVTEQ is sort of arbitrary, the content is virtually the same (in my opinion they both stink).
Garmin Backup means that you connect your GPS to your PC and copy all the original Map files from your GPS to your PC...
Hi all
Since this tread is a sticky I use it to give the info of the old gpsunderground forum and some other sources
Motzkus
Via-Michelin (France) lifetime subscription:
Use keygen 1.5 by JetMouse
Unit ID = TrafficReceiverID
select on "Select Map Product"
flag "enable additional fields"
insert FamilyID (MapID): 3898
ProductID: 29
RegionID: 32
VendorID: 1
V-Trafic (France) lifetime subscription:
insert FamilyID (MapID): 3902
ProductID: 30
RegionID: 32
VendorID: 1
TMC.IT (Italy) lifetime subscription:
insert FamilyID (MapID): 1330
ProductID: 1
RegionID: 1
VendorID: 1
TrafficMaster (United Kingdom) lifetime subscription:
insert FamilyID (MapID): 3072
ProductID: 7
RegionID: 7
VendorID: 1
ITIS (UK)
3082/10/10/1
TotalTrafficNetwork (USA) lifetime subscription:
Use "EXTENDED" (5 digit for FamilyID) keygen 1.5 by JetMouse
insert FamilyID (MapID): 28992
ProductID: 0
RegionID: 0
VendorID: 1
TMC PRO Germany
7474/1/1/1
NAVTEQ (US,CAN) lifetime subscription:
insert FamilyID (MapID): 28935
ProductID: 0
RegionID: 0
VendorID: 1
TOURING MOBILIS (Belgium) lifetime subscription:
insert FamilyID (MapID): 13827
Product ID : 1
Region ID : 1
Vendor ID : 1
Finland,
1537/17/17/1. Doit fonctionner pour les 3 pays. Shoud work for the 3 countries.
LE MIEUX! The best!
Finland
9729/17/17/1
Sweden
11778/33/33/1
Norway
12033/49/49/1
YouŽll need all three for Finland, Sweden and Norway.
Traffic codes for Australia
Name (Country) MapID / ProductID / RegionID / VendorID
Suna (AUS-ACT) 16641 / 53 / 53 / 1
Suna (AUS-NSW) 16897 / 54 / 54 / 1
Suna (AUS-VIC) 17153 / 1 / 1 / 1
Suna (AUS-QLD) 17409 / 56 / 56 / 1
Suna (AUS-SOA) 17665 / 57 / 57 / 1
Suna (AUS-WEA) 17921 / 58 / 58 / 1
Suna (AUS-TAS) 18177 / 59 / 59 / 1
Suna (AUS-NTY) 18433 / 60 / 60 / 1
Pour la SLOVENIE 18689/33/33/1
i have used latest NT 2011.20 map on sd card and the map is working fine. but my traffic is not working. once i use the original map on my garmin device, the traffic works fine. i have the original cord. any reasons?? any suggestions?
@ wantsong:
First:Make a backup of your old map to your computer.
Then: put the new map on the flash disk of your device(in case you have enough free Mb on your Flash Disk)
ow your traffic messages will appear again on your screen
Greets,
Bielgeets
Bielgeets:
you mean copy the map on garmin device instead of using it on sd card?
currently; i have the original map on garmin device and i copied new map on sd card.. when i use only original map; the traffic works fine.. once i use the map from sd card (NT 2011.20); the traffic reception is there and it says no delay but there is delay..
thanks in advance..
Anybody has any info on Garmin MSN Direct Hack??
I know i saw something but I can not find it anymore.
Any help is appreciated.
