Page 1 of 10 123 ... LastLast
Results 1 to 10 of 97
Thread: Garmin Bluecharts Issues
    trobador is offline Corporal
    18
    I was looking for GARMIN US RECREATIONAL LAKES FISHING HOT SPOTS for a week now,is there any one that has a copy of this,i will like to do some lake fishing for a change more so now that we have that oil navegating the Golf and we are in Florida.
    Thanks a lot for your help
    Trobador
    JEFFB is offline Lance Corporal
    [solved] Help appreciated - Bluechart Americas
    Hi
    Thanks to all for being back on-line.
    Does anyone have Bluechart Americas 2008.5 ( I think this was the last version for BC ?) - map code would be appreciated too.
    Jeff
    p!xeldealer's Avatar
    p!xeldealer is offline Sergeant
    44
    Re: Help appreciated - Bluechart Americas
    here you find, what you are looking for,
    all maps are unlocked, so you need no code
    gpsu Guest
    Re: Garmin us recreational lakes fishing hot spots
    nix4096 is offline Paid Member
    Which BlueCharts work with Mobile XP (PPC)
    Can you tell me which version of BlueChart work with Mobile XP under WM 6.1
    44
    Re: Which BlueCharts work with Mobile XP (PPC)
    BlueCharts only work korrektly with marine-chartplotters and outdoor-devices with marine-mode.
    All others (nuvi, mobileXT, mobileXP...) have display-errors, like wrong deepness-coloring, wrong symbols of navigation marks etc.
    Problem with Garmin BlueChart install
    I have a Garmin 755T. When I install:
    Garmin BlueChart G2Vision - HXUS039R - Entire Us (v11.00) - Unlocked
    To my SD card and reboot, I have 2 maps labeled HXUS039R in my list of available maps.
    This does not seem right. Any ideas what I am doing wrong if anything?
    balticsailor is offline Private
    Re: Problem with Garmin BlueChart install
    It is not wrong, bluecharts have always two entrys - one for the map and one for the marine-services.
    sibow is offline Private
    hello all , i downloaded a bluechart for norway which was unlocked, i stuck it on a mini sd card and it works a treat on my oregon 450 , however i find the screen really small and woudl be nice to do some research into fishing spots on the pc, is there anyway to view the map on the pc and pick spots to enter on my oregon. also is there a view that will tell me what all the symbols mean on the chart like the plus signs etc.
    thanks in advance to any help .
  10. The Following User Says Thank You to sibow For This Useful Post:
  11. #10
    3,132
    223
    re: Garmin Bluecharts Issues
    Bluechats use mapsource to view after installation.
    G2 vision use homeport to view
