Page 14 of 16 FirstFirst ... 41213141516 LastLast
Results 131 to 140 of 157
Like Tree2Likes
Thread: Garmin Nuvi Problems Discussion
  1. #131
    casaufficio is offline Corporal
    May 2011
    22
    20
    Re: Voice without guiding but with warning sounds?
    .......se invece non hai il XT ma un nuvi/zumo, dovrai installare una vove-guida muta e selezionarla al posto di quella che usi solitamente
    ......if you do not have the XT but a nuvi/zumo, you will need to install a guide vove-mute (silent) and select it instead of the one you use often
    Byebye...giorgio
  2. #132
    Skarek's Avatar
    Skarek is offline Private
    Quote Originally Posted by casaufficio View Post
    Where do I find a voice like this?
  3. #133
    Boneyy is offline Private
    Dec 2011
    Re: Lost Boot image, only getting text on startup
    How to remove Pin from nuvi 660 and nuvi 1240? i tried reset user data but no sucsess pllease inbox
  4. #134
    TCIII is offline Staff Sergeant
    64
    Quote Originally Posted by Boneyy View Post
    I'll make it short and sweet......you can't........unless you start from 0000 to 9999 and see if you get lucky
  5. #135
    viculet is offline Lance Corporal
    In according to the owner's manual nüvi® 610/660/670 you must send your nüvi
    to Garmin to get it unlocked if you forget your PIN and your security location.
  6. #136
    Oct 2012
    Re: [INDEX] Garmin Models Listing
    Hi I have an excess stock of 300 Garmin units GVN54 brand new and unused. Stock is based in UK starting price £325 each.
    Please email me for me info
  7. #137
    Oct 2012
    Re: POI visibility on map
    can somebody please help me? My nuvi is not recognized by computer and it would not go to premood. I cannot reset is nay ways. Is their any hope that I can revive the unit?
  8. #138
    sug172 is offline Sergeant
    London
    39
    Garmin repair
    Hi, does anyone know somebody who can repair garmins (And other sat navs) I have accumulated quite a few faulty ones over the years and would like to get them fixed.
    A
  9. #139
    Sniper's Avatar
    Sniper is offline Sergeant
    South Africa
    37
    Find the small pinhole at the back of the unit and reset it there.
  10. #140
    Sniper's Avatar
    South Africa
    37
    Re: Which Car model supports loading tracks w/o locking to roads
    Maybe a handheld unit like the Colorado will be best.
