Page 2 of 16 FirstFirst 123412 ... LastLast
Results 11 to 20 of 159
Like Tree2Likes
Thread: Garmin Nuvi Problems Discussion
  1. #11
    denniz94's Avatar
    denniz94 is offline Sergeant
    47
    Re: can somebody help me
    Quote Originally Posted by wally1 View Post
    Hi denniz94
    If your Garmin device has all the speed cameras loaded as per instructions you must check that your device is set to alert you, go into settings and depending on your device turn on alarms for alert once (single tone) or continuous tone.
    Since you have not mentioned what device you have I can't be more specific but try clicking on the settings (spanner) and maybe find Proximity Alarms and make sure they are ticked.
    Hope I helped
    ok im gonna try thanks
  2. #12
    Street name
    HI, Is there any garmin device that shows name of the street driving while navigating just like tomtom?
    Thank you
  3. #13
    3,132
    223
    Post your problems about garmin nuvi here.
  4. #14
    Re: nuvi 265t not starting up
    @nickwaah - did you do any FW upgrade lately?
  5. #15
    cuius is offline Sergeant
    37
    Nuvi battery recall
    If anybody is caught up in the nuvi battery recall:
    ...may be politic to review the "data" on the unit before sending - probably not a problem, but....
  6. The Following 2 Users Say Thank You to cuius For This Useful Post:
  7. #16
    jale is offline Corporal
    15
    40
    Re: Nuvi battery recall
    My 770 has been recalled. What do you recommend I do before I send it? Hard reset (after back-up of course)? Map removal? Does hard reset reset the maps to the original ones?
  8. #17
    MikieP is offline Corporal
    25
    Hard reset will do nothing about any of the non-Garmin supplied maps (i.e. gmapsupp.img, gmapprom.img, gmap3d.img, nor the JCV files) installed. Only way to get them restored would be to restore from a backup which I hope you have kept if updating was done through other than Garmin purchase or download.
  9. #18
    mikeockisitchy is offline Sergeant
    36
    I opened the Garmin Nuvi 255W and I don't see a reset button??
  10. #19
    3,132
    223
    Quote Originally Posted by mikeockisitchy View Post
    Read post #9 properly
  11. #20
    fortuner2010 is offline Sergeant
    37
    hi airion..good day,i just read you post here regarding on how to reset the satnav..i had a nuvi 205w and its working fine,i had two maps installed the ME map which is installed on the which is in the garmin main drive and the other map RG is in the SD card,recently when i'm trying to connect my nuvi to PC i was not able to view my SD drive only the main drive of my nuvi,i tried also to double checked whether my SD is faulty by plugging into my laptop but its working fine i see or read the contents of my SD card i was also able to view pictures from as what i can do on my nuvi before,is my slot card on my nuvi faulty?is there any ways to fix it...
