what about maps we may have obtained here, i guess it would be advisable to remove these any any personal info befor sending them in? back up and then delete?
anyone had theirs swapped yet? i got an email today suggesting i take it to a local retailer and they would "replace" the device, if this is the case are their models available now to avoid.
morning all, i have acquired a nuvi310 regrettably it is pin locked dont suppose there is a way to bypass this???
hi, there is a reset button visible on the rear just above the sticker,i take it this is not the one to hard reset??
i read on fixya forum that pins and security destinations are exempt from master reset? not much option then
than to give it a go, cheers
hi , i drill small hole under sticker but no master reset square button on this model 310! never mind worth a try.
Hello. I have updated maps in the Garmin Nuvi 255 but since that, I can not find any address using the postcode or address search. No countries are listed even though I put maps of the whole Europe. Could someone tell me what to do? My parrents are complaining that it is useless now. Thanks
Matt.
I cant remember how I did it as it was quite a long ago. Maps are accessible in the GPS and MapSource as I remember I was unlocking them, GPS navigates properly to the point on the map if selected manually, I does not work with postcodes or addresses though. It does not give any sign of being locked when starting, the GPS behaves in the same way it did before updating. I was using the Garmin Unlock Generator as far as I remember.
I can provide more information soon, I just need to get hold of this GPS unit :/ It's in the car now...
