Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 159
Like Tree2Likes
Thread: Garmin Nuvi Problems Discussion
    Sentosa is offline Corporal
    Sunshine Coast, Qld
    26
    Just thought I would throw this out there. If one buys a GPS in the Northen Hemisphere which has say, North American maps on it and brings it down to the Southern Hemisphere and puts lets say Australian and New Zealand maps on an SD card, does the satellite recognise the GPS and see the Australian and New Zealand SD card? I know there is one way to find out but haven't gotten around to it yet.
    Decided to do the obvious and yes it does work. Satellite sees the garmin and the SD card and/or vice versa no problems.
    Tiger is offline Major
    USA
    808
    Re: Different Satellites for different locations?
    Quote Originally Posted by Sentosa View Post
    Well. for the record... satellites don't recognize anything and know nothing about any GPS. It is the GPS that receives signals in the form of messages from the various satellites. In the simplest terms, satellites transmit their position and the time of day. Once the GPS can receive satellite position and time information from the transmitted messages of 3-4 different satellites it is able to triagnulate it's own position and that is totally independent of any maps you may have loaded. The purpose of the maps you have loaded is to help YOU make physical/relative sense of where you are currently located. Maps serve as references to your location.
    For exmple: If you had maps of North America and Europe loaded and you were on a boat in the middle of the Atlantic, your GPS would show you located the middle of the ocean (empty blue space) and your loaded maps would be of no value except to let your know where you are relative to them.
    Tuziukas is offline Lance Corporal
    Garmin PIN code remove
    Hello, i want to know, it is posible unlock garmin pin code?where i can find software?
    pierre likes this.
    sparkee is offline Lance Corporal
    How do I get an image on an sd card?
    I found an .img map and now how do I put it on the sd card? ... I have it in a garmin folder I made on the sd card and the file is named gmapsupp.img... do I need another file or anything?
    dexex is offline Private
    Re: How do I get an image on an sd card?
    If the maps are unlocked, you don't need anything else! If not, you need another file called "gmapsupp.unl" that contains the unlock code for your map. Search on google for "garmin jetmouse keygen"! It's easy to use! Hope it helps!
    What wil happen... If I update firmware by
    What wil happen...
    If I update firmware with updater by change gupdate.gcd to gupdate.rgn
    HaTeVe is offline Corporal
    Re: What wil happen... If I update firmware by
    Please try and let us know.
    denniz94's Avatar
    denniz94 is offline Sergeant
    47
    [solved] can somebody help me
    can anyone help me with with speedcameras i did this but it show the speedcameras but its quiet, it dont alarm me, can anybody help me ,
    wally1 is offline Staff Sergeant
    97
    20
    Re: can somebody help me
    Quote Originally Posted by denniz94 View Post
    Hi denniz94
    If your Garmin device has all the speed cameras loaded as per instructions you must check that your device is set to alert you, go into settings and depending on your device turn on alarms for alert once (single tone) or continuous tone.
    Since you have not mentioned what device you have I can't be more specific but try clicking on the settings (spanner) and maybe find Proximity Alarms and make sure they are ticked.
    Hope I helped
    Sniper's Avatar
    Sniper is offline Sergeant
    South Africa
    37
    Question POI visibility on map
    I'm reffering to the Tracks4Africa map.In Mapsource POI's like tented camps,fishing spots,gravel sections are all visible.After transfer of the map to my unit none of these symbols are visible on the unit.What is the reason for this? Thanks
