Page 2 of 29 FirstFirst 123412 ... LastLast
Results 11 to 20 of 290
Thread: Garmin Maps Issues
  1. #11
    Don Jordan is offline Private
    [Solved] Garmin City Navigator Europe NT 2011.10] Unlock Problem
    I have downloaded the Europe 2011 map for Garmin. I have tried to unlock it, but I can't.
    I used the patched Mapsource version and the JetMouse keygen generator. When I put the code in the "unlock regions" section, the map seems to be unlocked, but I can't select the map to send to the SD Card.
    I have tried to do it with the MapInstall but it appears a message who says the map is locked...
    What is the problem? Can anyone help?
    Thank you,
    Don Jordan
  2. #12
    p!xeldealer's Avatar
    p!xeldealer is offline Sergeant
    44
    Re: [Garmin City Navigator Europe NT 2011.10] Unlock Problem
    just use the unlocked version!
  3. #13
    silvereel is offline Sergeant
    31
    what mapid are you using
  4. #14
    [solved] Garmin City Navigator Europe NT 2011.10 Unlock Problem
    Thank you, but I solve the problem! I send the map to the nuvi from MapSource...
    Thanks,
    Don Jordan
  5. #15
    Re: POI Truck Stops/Fueling Stations
    have a look on
    http://www.poiplaza.com/
  6. #16
    [solved] How to create just Canada maps from CNNA 2011
    After getting the CNNA 2011 unlocked image, can I just create a SD card for Canada only?
    My nuvi only has the 48 US only, and does not have room for all of North America.
    I would like to just create an SD card with Canada for use when I need it.
    Can I use mapsource 6.13 and creeat the Canada maps?
  7. #17
    Ipmark's Avatar
    Ipmark is offline Command Sergeant Major
    207
    Re: How to create just Canada maps from CNNA 2011
    No.
    But you can use Gmaptool to split the single maps, then choose the Canada region maps and join them in a only Canada map.
    or
    Download it from HERE.
  8. #18
    Re: Garmin City Navigator Europe 2011 unlock problem
    many thanks radijator123, slapped the mapsource.exe file in and used the keygen and it works perfectly on my nokia 5800! still hasn't updated the local road works near me though so i'm expectin the tracking to go funny when i next hit it in the car! ah well! thanks again!
    johnsbegood
  9. #19
    windsurf20 is offline Lance Corporal
    [Request] How to unlock TOPO FRANCE V2
    Hello
    I Have Topo France v2 loocked in Mapsource.
    How to unloocked it ?
  10. #20
    Re: [Request] How to unlock TOPO FRANCE V2
    # MapID: 390 Topo France V2
