20th October 2012, 18:31
#271
Re: My Brain is Freakin Confused!! Edit map???
Dear Tiger
Thank you very much for your quick response. I will do everything as you told and will let you know about the result.
Thanks again
16th November 2012, 10:43
#272
Re: Battery Life and microSD cards
I have used mine for 3 years now, and once I had to use without the card for 3 months, it doesn't have a noticeable difference.
16th November 2012, 10:45
#273
Re: POI Truck Stops/Fueling Stations
I had a similar problem with the map, but after wasting my time for 4 days, I took mine back to the company where I bought it, and there I had the experts fix the problem, and everything has been great ever since.
2nd December 2012, 02:06
#274
Re Map.
I have a Nuvi40, have downloaded the unlocked image file, when I start the Garmin, it loads the lastest map then says 'Unable to authenticate maps, it then goers past that to the 'Where To' screen and all seems OK.
How do I get rid of the 'Cant authenticate Map'.
Thank you in advance.
Edit Sorry under wrong heading.
Reason: Error
2nd December 2012, 02:07
#275
Re: Garmin Maps Issues Unable to authenticate Map
Re Map.
20th December 2012, 14:35
#276
Copying from Garmin to Garmin
I've got a Zumo with lifetime updates. Also got a Nuvi with old map. Is there any way of copying the map from the Zumo to the Nuvi?
I have looked for an IMG file on the Zumo, but can't find it .... even with all filed unhidden.
Cheers
26th December 2012, 13:22
#277
Unlock Dvd
Good day
Is there anyway to unlock the latest garmin maps from dvd.
I have tried everthing i can find in the forum.
Detailed instructions if possible please.
26th December 2012, 13:50
#278
Re: Unlock Dvd
If that is an original DVD, see this totorial about installing and unlocking:
How to install and create a map with Original Mapsource Locked
26th December 2012, 13:53
#279
Re: Unlock Dvd
Simply, the copy img from DVD to your PC or SD card then use this:
Garmin Image Unlock gimgunlock v.0.03
Not need to write thanks .... just CLICK Thanks or Like or add reputation
28th December 2012, 13:18
#280
Garmin FM Traffic signal
Ok guys
Not the end of the world but went to the US with my Nuvi 1490 (Europe map) and fully loaded SD card for North America with Junction views + City explorers
and all worked fine no problems
But wait all the way from Las Vegas to San Francisco and back down to Los Angeles without any FM traffic reports, the two little cars symbol didn’t show up once,
I did look through the settings but still no joy, So what haven’t I done is there a compatibility problem,
Ok I just know someone is going to make me look silly
Back over to Florida next year so be nice to have it working
Many thanks to all correspondences
