Page 1 of 29 12311 ... LastLast
Results 1 to 10 of 290
Thread: Garmin Maps Issues
    Garmin Maps Issues
    Does anyone know how to unlock this one? I have tried to generate code but I get still the error map locked.
    I want to unlock it on my computer because the nuvi250 that I have doesn't have enough space ( only 1.3G) and I want to manually select.
    Many thanks for any info.
  2. The Following User Says Thank You to bandyt For This Useful Post:
    lolypop000 is offline Sergeant
    49
    Re: Garmin City Navigator Europe 2011 unlock problem
    Buy SD card 4Gb
    radijator123 is offline Lance Corporal
    If you're talking about Mapsource version of the CN Europe 2011.10, you probably didn't replace the original mapsource.exe file with the patched one, link is at the bottom. You can find it in the folder C:\Garmin if you didn't choose a custom folder for the installation.
    Here is how to for the full process of unlocking the map after you've replaced your mapsource.exe file:
    0. Start the keygen
    1. On the top of the keygen type in your device serial number
    2. On the lower part of the keygen (NOT the middle one where it says Garmin Mobile XT) click on the drop down box and select <custom mapset>, enter 2204 and hit OK
    3. Press "Generate"
    4. Go to Mapsource
    5. Utilities > Manage Map products
    6. Unlock Regions > Add
    7. paste the unlock code in the upper field
    8. Hit OK
    Patched Mapsource.exe here
    http://rapidshare.com/files/34769993...E_jetmouse.rar
    JetMouse keygen here:
    http://rapidshare.com/files/347700009/JMKG15.rar
    bowser is offline Sergeant
    36
    Garmin Maps Issues
    Are there any POIs showing truck stops with diesel fuel along I95 and I4 that I can load into my nuvi?
    sucro's Avatar
    sucro is offline Staff Sergeant
    91
    21
    Just use this
    Garmin unlocker
    Unlock all garmin city navigator 2008,2009,2010 maps used in MAPSOURCE,and after use them for sending to your device - ALL Garmin GPS devices,Nokia N97, Nokia N96, Nokia N95, Nokia N95 8gb, all nokia phone which have GPS reciever ,and all PDA, smartphone, etc which use GPS over bluetooth, or assisted GPS, internal, and operate on Windows Mobile, Garmin Mobile PC, etc.. , without any problems, after unlocking device with garmin keygen 1.5.
    http://rapidshare.com/files/22651891...n_unlocker.rar
    1. Install MapSource
    2. Install Maps - in c:\garmin
    3. Use attached unlocker - just extract and run bat file
    4. Using MapSource transfer maps to device
    5. Be cappy !
    uploaded by Sucro , 100% working
    JohnnysPT is offline Private
    Hi.
    Do you know if i can do this for an old Garmin Ique 3600 with SD Card ?
    Regards,
    Rui
    [solved] What is DLC file and how to load?
    How can I use a DLC file? I downloaded it using jdownloader but it's a dlc file. How can I extract it?
    Help will be greatly appreciated.
    zuzka is offline Corporal
    18
    Re: DLC file
    Open the DLC file with Jdownloader or doubleclick on it. You shold see new link packs under jdownloader`s tab Links
  10. #9
    sucro's Avatar
    91
    21
    Re: DLC file
    use some apps like cryptload, jdownloader etc. to download that files, DLC file isn't full content of file which you want to download, it's just container of links, with JDOWNLOAD program open it
    jdownload you can download here, latest version
    http://x7.to/b1zen4
    after loading .dlc file in jdownload , you'll see all links in program, and just start downloading, after finishin of downloading all links, in d:\jdownoader you'll have all files which you'll can extract ...
  11. #10
    36
    Re: POI Truck Stops/Fueling Stations
    Can a mod move this post to Garmin POI?
