Results 1 to 1 of 1
  • 1 Post By bam-bam
Thread: TOPO Czech 2011 PRO + CYKLO Czech 2011
    bam-bam's Avatar
    CYKLO Czech 2011NT (318.73 MB) mapsource FID 1712 - upload your files to multiple file hosting sites!
    CYKLO Czech 2011NT img.rar (253.53 MB) unlocked image - upload your files to multiple file hosting sites!
    Included data layers
    • Road network - as of February 2011.
    • Hon Network - divided into routovatelné (verified) and neroutovatelné, including paths.
    • Cycling - a layer of marked cycling routes, usually marked by a number.
    • Marked hiking trails - marked trails, marked with color lines, plus some nature trails.
    • Buildings - plotting of individual buildings.
    • Rivers, lakes and swamps - a complete layer of waters from the state map series with details of scale 1:10 000
    • Forests, woods and line of vegetation - a complete layer of vegetation from the state map series with details of scale 1:10 000
    • Elevation - the height points, and peaks with contour interval 20 m.
    • Rail network
    • Line of vegetation along the roads
    • Points of Interest - POI dozens of categories with a total of over 70 000 elements
    • The map contains other elements, such as railroads, rock formations, ski lifts, industrial parks, vineyards, hop fields.
    • Digital terrain model (used for shading in MapSource program).
    • The installation program includes maps MapSource version 6.15.7 with updates to version 6.16.3, including the Czech localization.
    Compatible devices
    Bicycle Map 2011 NT is only compatible with Garmin devices that support NT format. List of supported navigation: eTrex Legend Cx / HCx, eTrex Vista Cx / HCx, Edge 605/705/800, a series of Colorado, Oregon, Dakota and Montana, GPSMAP 60 Cx / CSX, GPSMAP 62, Nuvi series, Zumo, or even older models Quest, StreetPilot i series C.
    Description of the maps and route calculation method set
    An important finding, which we obtained at least a cycling test in the field is the difference in the calculation of routes for different types of navigation, Garmin. Outdoor and cyklonavigace when calculating routes too prefer cycling cyclist and tries to lead a network of roads with a preference for the shortest route and outside the busy road. If the calculated route to the goal to lead the cycling route, then it tries program in the PC or device used in the field.
    TOPO Czech PRO 2011 (434.88 MB) mapsource FID 1711 - upload your files to multiple file hosting sites!
    TOPO Czech PRO 2011 img.rar (368.65 MB) unlocked image - upload your files to multiple file hosting sites!
    The new version of tourist and navigation map of the Czech Republic designed for most Garmin GPS map.
    United TOPO 2011 is a tourist map in 1:25 scale
    New and improved
    • New, refined and complete plotting of road and street network in the Republic, as of the end of 2010. Significant additions backbone network quality of forest and field trips (routovatelné added to the layers). More than 100,000 new sections of roads. In addition, complement and refine the course of approximately 3,000 sections of other routes.
    • Marked hiking paths and cycling routes: about 1200 repairs done over the marked paths, new additions and cancellations nevyznačených.
    • Peaks - complete and more accurate at about 150 peaks. Added some seats (about 200 elements).
    • Foreign belt 500 m - minor corrections and additions of approximately 800 elements
    and about 450 points of interest in various categories.
    • Points of Interest - A new comprehensive database of Jewish Monuments (450 points) and municipalities (4400 points), completion Mills (150 points), protected trees (300 points), the update stamp of tourist sites and towers. Extending a database of tourist signposts and landings (1600 points). Removing duplicates, precise positioning and completion of attributes in about 5000 points. Added more parking (3000 points), restaurants, hotels.
    Basic description of the maps
    Map was combining hiking and navigation data from several data sources. The most used line in the map above polohopisných and topographic features of the state. map series, which adds a number of map elements and polohopidných altimetry. Density display elements corresponding to approximately 1:25 scale 000th In addition, communication lines are lines drawn on the map tourist trails, cycling, high-voltage lines, nature trails and trips for thousands. Furthermore, the map contains relief shading, so visually active relief and topography of the terrain it is easier to read. Shading maps feature allows you to display all route elevation profile. Shaded relief route and profile of the shaded data can only be viewed on a computer program MapSource, not in the GPS device.
    Networks tourist. brands, bike trails, nature trails and paths with thousands of trips are colored. Color map symbols do not display all devices produced by Garmin. This offer functional devices manufactured since 2006 and more recently. Namely include an eTrex Venture Cx, eTrex Legend Cx, eTrex Vista Cx, GPSMAP 60 Cx, GPSMAP 60CSx, GPSMAP 62s, 62st GPSMAP, GPSMAP 76Cx, GPSMAP 76 CSX, GPSMAP 78, S-series c5xx StreetPilot, Nuvi, Zumo, Colorado , Dakota, Oregon, Montana, GPSMAP 278 and Garmin Mobile 10th
    Map contains the following map elements:
    • seat and the seats (20,000 points)
    • Points of Interest in over 50 categories (eg, ATMs, sights, restaurants, buildings MS. Fortification, trademark tourist places, sports, entertainment, railway stations and stops),
    • height dimensions (65,000 points)
    • Network Communications - highways, highway I-III. classes, paved asphalt, streets in cities and local roads in the villages, important forest and field trips (over 1.1 million chunks!)
    • Railroad and some railway sidings,
    • keeping a very high voltage (110, 220 and 400 kV)
    • rivers, streams,
    • contour with a step of 20 meters,
    • tourist signs,
    • cycling,
    • nature trails,
    • Recommended tours of thousands
    • areas of settlements and large towns shopping area, university and other areas
    • forest area,
    • surface-water reservoirs, lakes, ponds and small lakes blank,
    Unsupported devices: GPS 12Map,
    GPS III +, eMap / eMap Deluxe, StreetPilot, StreetPilot and StreetPilot III ColorMap
    Thanks to catymag
    Yave likes this.
  2. The Following 8 Users Say Thank You to bam-bam For This Useful Post:
