Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Like Tree4Likes
Thread: [Benelux] Topo 2010
    Bascy is offline Private
    [Benelux] Topo 2010
    lgmge and Kiske like this.
  2. The Following 20 Users Say Thank You to Bascy For This Useful Post:
    AHMHeeren is offline Sergeant
    The Netherlands
    57
    Re: [Benelux] Topo 2010
    Bascy,
    thanks, but how to install ?
    I have on my SDCard a gmapsupp.img file allready.
    After unpacking Benelux Topo 2010 I got a directory with all kinds of different .img files.
    How to store them on the SDCard to make it work ?
    I see a install.bat (ms dos) file, should I use that or what ? Does this create a file or subdirectory I can store on my SDCard ?
    THX/Ton
    asprin624's Avatar
    asprin624 is offline Lieutenant
    Belgium
    446
    251
    Thank You
    Will give this a try today
    qrumba's Avatar
    qrumba is offline Sergeant
    32
    120
    Hi AHMHeeren!
    The install.bat will install the map in MapSource (and BaseCamp).
    With MapSource (or MapInstall) you can send the map data to your device (or to SD Card, USB stick or similar).
    You have to use the Map Tool to select the desired parts (tilles) of the map and send it afterwatrds to your device. MapSource will create an object named gmapsupp.img and therefore will overwrite an object with the same name on the selected device. You should use a new SD card (or rename the gmapsupp.img file) before sending the new map. If your device is a Oregon or Dakota you can use every name for map files (ending with .img).
    Best greetings,
    qrumba
    The map is unlocked and fully routeable. MapID 1725. Thanks!
    AGRINCO is offline Private
    Where I can find the password in order to open the .rar file?
    Michigan is offline Private
    PW is 20!0
    Hi
    It seems that i miss something...
    Do i have to own the MapSource (or MapInstall) to be able to put the map onto my Nuvi 1310 ?
    If yes - where/how can i find them for a free usage ?
    regards,
    tavi
  10. #9
    Hello
    thank you for work,is it possible to obtain this map in french ?
  11. #10
    RedC is offline Private
    I am unable to see this map in Mapsource or Basecamp.
    I managed to put the map on m device (Edge 605)
    Can anyone explain me how to proceed?
    Many thanks!
  1. 6th May 2011, 10:22
