Page 1 of 7 123 ... LastLast
Results 1 to 10 of 66
Like Tree5Likes
Thread: Philippines Road Guide Contributors v2.07
    MobileXT is offline Lance Corporal
    RG v2.07 FileSwap.com : Roadguide.ph_Contributors-2.07.rar download free
    unzip the file and copy all into the directory c:/jklink/roadguide.ph and run the registry inside and you have succesfully intalled rg v2.07.
    Last edited by bjjfc; 5th May 2012 at 03:46. Reason: create new thread & rename title
    ROEL_V likes this.
  2. The Following 4 Users Say Thank You to MobileXT For This Useful Post:
    leandrolics is offline Private
    Mar 2012
    Re: Philippines Road Guide Contributors v2.07
    nice share....however its locked. how to unlock?
    Apr 2012
    @MobileXT - I was able to install into Mapsource and unlock with JetMouse. However, after dowloading to my Nuvi260w via Mapsource the POIs are not searchable. Any clues on what I am doing wrong?
    Quote Originally Posted by leandrolics View Post
    you can search here how to unlock Fast IMG Unlocker
    ozboss's Avatar
    ozboss is offline Second Lieutenant
    291
    16
    Download Instructions:
    Philippines Road Guide v2.07 or Download netload Philippines Road Guide v2.07
    MapID: 630
    password: ozboss18
    inside:
    unloked image file
    unlocked mapsource folder
    run reg file on 32BIT System
    if you used 64 BIT changeg open reg file with editor and change line
    HKLM\SOFTWARE\Wow6432Node\Garmin\
    or use MapSetToolKit
    Hoster
    netload.in
    share-online.biz
    clusterdavao likes this.
  7. The Following 4 Users Say Thank You to ozboss For This Useful Post:
  8. #6
    Quote Originally Posted by uvax View Post
    Make sure everything is selected when you transfer to your gps device. Mine is everything ok.
  9. #7
    Apr 2012
    Quote Originally Posted by MobileXT View Post
    Realized my mistake. Everything works now. Thanks.
  10. #8
    Mar 2012
    Thanks guys for the info in unlocking and also for the sharing unlocked version...the problem again is the thin roads. I tried using the procedure applying typ_lib from previous forum (v2.01) however without success. If you guys can upload the typ_lib applied will be appreciated.
  11. #9
    Apr 2012
    The rar file in MobileXT's post includes the TYP file "126FC.TYP". That will give you the thick roads that you like.
    If you're using MobileXT's mapsource files it is easy to change the TYP. Just open "RoadGuid.reg" in notepad and change "0276.TYP" --> "126FC.TYP" and then save. Double-click on "RoadGuid.reg" to enter it into windows registry and you should have the thick roads now when you open Mapsource.
  12. #10
    mblue is offline Sergeant
    May 2011
    30
    Quote Originally Posted by ozboss View Post
    MapID: 630
    password: ozboss18
    inside:
    unloked image file
    Hoster
    netload.in
    share-online.biz
    I've replaced my old version using this link...I used the "unlocked image file" and it works okay.
    don't be surprised though if the roads are thin... this could easily be customized using the "TYP FILE".
    Thanks for the help sir ozboss
