Thread: BlueChart g2 Vision - VAE002R - Yellow Sea
    P33dro's Avatar
    P33dro is offline General
    Australia n.s.w.
    BlueChart g2 Vision - VAE002R - Yellow Sea 2015.5 (17.00)
    General coverage of the Chinese coast from Wenzhou to Dandong; the South Korean coast in its entirety; the full west coast of North Korea and the east coast south of Kimch'aek. Included in this overall general coverage are numerous detailed charts covering areas in China such as Shanghai, Qingdao, and Dalian; and also Nampo, N.Kor., and Pusan, S. Kor
    FID: 3852, PID: 1, RID: 3, VID: 2
    Locked Image:
    UnLocked Image:
    bam-bam's Avatar
    Re: BlueChart g2 Vision - VAE002R - Yellow Sea
  4. The Following User Says Thank You to bam-bam For This Useful Post:
