  • 1 Post By P33dro
Thread: BlueChart g2 Vision - VEU019R - Alborg-Amsterdam
    P33dro's Avatar
    P33dro is offline Lieutenant General
    1,601
    53
    Version: 2012.5
    Released: Aug, 2012
    Part number: 010-D0447-00
    See your vessel’s precise, on-chart position in relation to navaids, coastal features, restricted areas and more with premium features found in this detailed marine mapping data. Includes all of the BlueChart® g2 features, plus 3-D perspective above and below the waterline, Auto Guidance, high-resolution imagery, and aerial photos of ports, harbors, marinas, landmarks and other points of interest.
    • Includes realistic navigation features showing everything from shaded depth contours and coastlines to spot soundings, navaids, port plans, wrecks, obstructions, intertidal zones, restricted areas, IALA symbols and more.
    • Features smooth displays, including seamless transitions between zoom levels and more continuity across chart boundaries.
    • Includes high-resolution satellite imagery, when overlaid on the chart, provides the mariner with a realistic view of the land and water for unparalleled situational awareness.
    • Features aerial “real world” photos of ports, harbors, marinas, waterways, navigational landmarks and other points of interest, offering the mariner another powerful tool for navigating unfamiliar waters.
    • Includes Auto Guidance technology that searches chart data - tides, currents, marine services, coastal roads and points of interest - to suggest the best passage to a destination.
    • Offers MarinerEye view 3-D perspective, providing a bird's eye view from behind the boat showing the chart information for a quick, reliable and easy position fix.
    • Offers FishEye view 3-D perspective, providing an underwater view that visually represents the sea floor according to the chart's information.
    • Provides Safety Shading (in compatible units), allowing mariners to enable contour shading for all depth contours shallower than user-defined safe depths.
    • Provides Fishing Charts (in compatible units), allowing mariners to scope out bottom contours and depth soundings with less visual clutter on the display.
    • Allows users to conveniently plan and organize routes, from your computer, before your trip with HomePort™, compatible trip-planning software (sold separately).
    Coverage Details
    Includes detailed coverage from Ålborg Bugt to Amsterdam, The Netherlands, including Limfjorden, Hamburg, Bremen and Emden.
    Locked Image: Part1 | Part2 | Part3 UnLocked Image: Part1 | Part2 | Part3 FID: 2656
    https://buy.garmin.com/shop/shop.do?pID=9195
    roofvogel likes this.
    bam-bam's Avatar
    bam-bam is offline Captain
    earth
    675
    50
    Re: BlueChart g2 Vision - VEU019R - Alborg-Amsterdam
    mirror
    Garmin BlueChart g2 Vision - VEU019R - Alborg-Amsterdam UNLOCKED.part1.rar
    Download fast and easy your files! - soCtRS
    Garmin BlueChart g2 Vision - VEU019R - Alborg-Amsterdam UNLOCKED.part2.rar
    Download fast and easy your files! - xQUUqX
    no need to write thanks ... just click like or give reputation
