Thread: BlueChart g2 Vision VUS036R - Inland Rivers v2013.0 (14.50)
    P33dro's Avatar
    P33dro is offline General
    Australia n.s.w.
    Detailed main channel coverage of the major rivers of the interior of the United States as part of the Great Circle Route. Coverage includes the Ohio, Illinois, Tombigbee, Black Warrior, and Atchafalaya Rivers in their entirety, as well as the Tenn-Tom Waterway in full. Coverage also features the Mississippi River from its junction with the Minnesota River above Minneapolis-St. Paul, MN to the Delta; the Tennessee River from Knoxville, TN to the Ohio; the Cumberland River from Celina, TN to the Ohio; the Allegheny River from East Brady, PA to the Ohio; the Monongahela River from Fairmont, WV to the Ohio; the Kanawha River from Montgomery, WV to the Ohio; the Green River from Rochester, KY to the Ohio; the Verdigris River from the Port of Catoosa to the Arkansas; the Arkansas River from its junction with the Verdigris River outside of Tulsa, OK to the Mississippi; and the Red River from Shreveport, LA to the Mississippi. General coverage of the Gulf of Mexico from Port Arthur, TX to Pensacola, FL; and the southern portion of Lake Michigan from Waukegan, IL to South Haven, MI.
    Locked Image:
    UnLocked Image:
    FID 2823
    bam-bam's Avatar
    Re: BlueChart g2 Vision VUS036R - Inland Rivers v2013.0 (14.50)
  4. The Following User Says Thank You to bam-bam For This Useful Post:
