Results 1 to 1 of 1
Thread: BlueChart g2 Vision - VUS510L - St. John - Cape Cod 2014.0 (15.50)
    P33dro's Avatar
    P33dro is offline General
    Australia n.s.w.
    Part Number: MicroSD/SD (010-C0739-00), Download (010-D0498-00)
    Detailed coverage the east coast of the U.S. and Canada from Cape Cod to St. John, NB, including Boston, MA, Portsmouth, NH, and Portland, ME, as well as the Kennebec R. to Augusta, ME and the Penobscot R. to Bangor, ME. Coverage also includes Martha's Vineyard, Nantucket Island, Grand Manan Island, Mt. Desert Island, and Calais, ME as well as St. Mary's Bay and Yarmouth, NS. Bathymetric coverage includes George's Basin, Franklin Basin, and the Northeast Channel.
    FID: 3245, PID: 1, RID: 4, VID: 27
    Locked Image:
    UnLocked Image:
