Thread: BlueChart g2 Vision - VEU050R - Gulfs of Finland & Riga 2014.0 (15.50)
    P33dro's Avatar
    P33dro is offline General
    Australia n.s.w.
    (VEU050R - Aland-Vyborg)
    Detailed coverage of the Gulf of Finland from Åland to Vyborg, Finland. Also includes detailed coverage of the cities of Turku, Helsinki, and Kotka in Finland and Tallinn and Kohtla-Jarve in Estonia.
    FID: 3247, PID: 1, RID: 2, VID: 53
    Locked Image:
    UnLocked Image:
    bam-bam's Avatar
    Re: BlueChart g2 Vision - VEU050R - Gulfs of Finland & Riga 2014.0 (15.50)
  4. The Following User Says Thank You to bam-bam For This Useful Post:
