Thread: Garmin Bluechart G2 Vision - VUS025R - Anchorage to Juneau
    cuge is offline Sergeant
    41
    VUS025R Anchorage to Juneau Bluechart G2 Vision (10.50)
    PID 1, FID 487, region 1,36
    locked original IMG
    http://www.megaupload.com/?d=09TNWG8G
    credits to catymag!
  2. The Following 2 Users Say Thank You to cuge For This Useful Post:
    WknThDg's Avatar
    WknThDg is offline Sergeant
    40
    VUS025R- Anchorage to Juneau (10.50) Unlocked
    Extract the attached file and use JDownloader or CryptLoad to download.
    This unlocked img will function exactly the same as the locked file posted above, but without the need to create a unl file that contains an unlock key.
    No other unlocking tools need to be used or applied.
    GMapTool "Details" below (I only included the 1st map tile in the "Code" box below but the rest of them are all unlocked as well):
    Header:		19.06.2008 20:48:36, DSKIMG, xor 00h
    Mapset:		VUS025R-Anchorage - Juneau (10.50)
    fat:		1000h - 1200h - 20000h, block 16384
    maps:		104, sub-files 105
    Sub-file         fat     length
     MARINAS  MDR   1200h     31482
     MARINAS  SRT   1400h       968
     00000099 GMP   1600h      1708
    	GMP:  TRE RGN LBL
    	map 7a90f8 (8032504)
    	date 19.06.2008 18:48:26
    	priority 28, parameters 0 2 31 3, transparent
    	levels [13,14,16,18,20,22,24], zoom [86,5,4,3,2,1,0]
    	N: 61.538973, S: 55.791492, W: -156.313906, E: -132.535973
    	GARMIN G-Map
    	Copyright 1995-2008 by GARMIN Corporation.
    	CP 1252, Western European
     BLUCHART MPS  1F400h      2986
    Map              length s-f  CP    prio  PID   FID  name
     MARINAS  IDX     32450  2
     00000099 NT       1708  1  1252   28  T   1   487  >-  >VUS025R
      BLUCHART MPS      2986  1
    Data MPS
     F: PID 0, FID 0, VUS025R
     L: PID 0, FID 0, map 7A90F8, (0 0),  -  >-  >VUS025R
     P: PID 0, FID 0, (0 19E 0)
    Attached Files Attached Files
