Thread: BlueChart g2 Vision - VEU001R - English Channel 2014.0 (15.50)
    P33dro's Avatar
    P33dro is offline General
    Australia n.s.w.
    BlueChart g2 Vision - VEU001R - English Channel 2015.5 (17.00)
    British coast: covers from Felixstowe to the Isles of Scilly, including Dover, The Solent, and the Isle of Wight. Also covers the River Thames from Twickenham to the North Sea. French coast: covers from Dunkerque to L'Aber Wrac'h, including Rouen and the Channel Islands
    FID: 3849, PID: 1, RID: 2, VID: 8
    Locked Image:
    UnLocked Image:
    bam-bam's Avatar
    Re: BlueChart g2 Vision - VEU001R - English Channel 2014.0 (15.50)
  4. The Following User Says Thank You to bam-bam For This Useful Post:
