Thread: BlueChart g2 Vision - VUS513L - Jacksonville - Bahamas 2014.0 (15.50)
    P33dro's Avatar
    P33dro is offline General
    Australia n.s.w.
    Detailed coverage of the Florida Peninsula from St. Mary's, GA through the Port of Miami to Fort Myers on the Gulf. Coverage includes the St. Johns River, Crescent Lake, Lake George, Lake Monroe, Lake Jesup, Lake Harney, Lake Okeechobee, the St. Lucie Canal, and Caloosahatchee R. in full. Detailed coverage also includes the Florida Keys, Bahamas and Turks and Caicos Islands. Bathymetric coverage of offshore features from Blake Canyon through Santaren Channel to the Torgtugas Terrace, including the Blake Escarpment and Great Bahama Bank.
    3245, PID: 1, RID: 4, VID: 30
    Locked Image:
    UnLocked Image:
  2. The Following 3 Users Say Thank You to P33dro For This Useful Post:
    Jul 2014
    Re: BlueChart g2 Vision - VUS513L - Jacksonville - Bahamas 2014.0 (15.50)
    this might be a stupid question but, i see the the map is broken into 3 files. do I need all 3 files or how to I handle them once downloaded?
    bam-bam's Avatar
