Thread: BlueChart g2 Vision - VEU010R - Mediterranean Sea, Genova-Ayamonte 2014.0 (15.50)
    P33dro's Avatar
    P33dro is offline General
    Australia n.s.w.
    Detailed coverage of the entire Spanish and French Mediterranean coast from the Straight of Gibraltar to La Spezia, IT. Includes coverage of Corse, the northern part of Sardegna, and the Islas Baleares. Also covers the northern coasts of Morocco and Algeria from Larache, MA, to Bejaia, DZ.
    FID: 3247, PID: 1, RID: 2, VID: 16
    Locked Image:
    UnLocked Image:
    bam-bam's Avatar
    Re: BlueChart g2 Vision - VEU010R - Mediterranean Sea, Genova-Ayamonte 2014.0 (15.50)
