Thread: BlueChart g2 Vision - VEU021R - Denmark East & Sweden 2014.5 (16.00)
    P33dro's Avatar
    P33dro is offline General
    Australia n.s.w.
    BlueChart g2 Vision - VEU021R - Denmark East & Sweden Southeast 2014.5 (16.00)
    • Plan and organize routes from your computer with HomePort™.
    Swedish coast: from Göteborg to Karlskrona, including Malmö and Trelleborg, as well as lakes Mjörn and Bolmen. Danish, German, and Polish coasts: Lemvig, Denmark to Szczecin, Poland, including Limfjorden, Skagen, Den., Copenhagen, Den., Stralsund, Ger., and the islands of Sjælland, Fyn, Møn, Falster, Lolland, Langeland and Fehmarn.
    FID: 3481, PID: 1, RID: 2, VID: 26
    Locked Image:
    UnLocked Image:
    bam-bam's Avatar
    bam-bam is online now Lieutenant General
    Re: BlueChart g2 Vision - VEU021R - Denmark East & Sweden 2014.5 (16.00)
