Results 1 to 9 of 9
Thread: Garmin GR & CY Maps In Sets (Auto Drive 1.99-Anavasi 4.50) & Auto Drive 1.99 Unlocked
    Santosan's Avatar
    Santosan is offline Sergeant
    52
    These sets contain full road network of Greece and Cyprus, off road map for Greece and nautical maps for both countries. All sets are fully unlocked, no need for unl file, just copy the set into Garmin folder. In these sets you can find the new version of Autodrive 1.99, Anavasi 4.50 & NT 2011.30GR. Tested and working: PNA, Garmin Mobile PC & N95.
    Available Sets Greek/Latin
    2in1 NT2011.30GR - Anavasis 4.50.....Latin ... New
    2in1 Auto Drive Hellas 1.99 el - Recreational Greece 3D 3.01
    2in1 Auto Drive Hellas 1.99 en - Recreational Greece 3D 3.01.....Latin
    2in1 Geomatic 3D Q7.1 - Recreational 3D 3.01 CY.....Latin
    2in1 Geomatic 3D Q7.1 - Bluechart Atlantic 2008.5 CY.....Latin
    2in1 Autodrive 1.99el - Anavasis 4.50 GR
    2in1 Autodrive 1.99en - Anavasis 4.50 GR.....Latin
    3in1 Autodrive 1.99el-Greek Anavasis 4.50 - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR
    3in1 Autodrive 1.99en-Greek Anavasis 4.50 - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR.....Latin
    3in1 Geomatic 3D Q7.1 - Recreational 3D 3.01 CY - Bluechart Atlantic 2008.5 CY.....Latin
    4in1 Autodrive 1.99el - NT2011.30GR - Anavasis 4.50 - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR
    4in1 Autodrive 1.99en - NT2011.30GR - Anavasis 4.50 - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR.....Latin
    5in1 Autodrive 1.99el - Anav 4.50 - Geomatic 3D Q7.1en - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR-CY
    5in1 Autodrive 1.99en - Anav 4.50 - Geomatic 3D Q7.1en - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR-CY.....Latin
    6in1 Autodrive 1.99el - NT2011.30GR - Anav4.50 - GeoQ7.1en - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR-CY
    6in1 Autodrive 1.99en - NT2011.30GR - Anav4.50 - GeoQ7.1en - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR-CY.....Latin
    6in1 Autodrive 1.99el-Anav4.50-GeoQ7.1- Recreational 3.01 CY- Bluechart 2008.5 Tides-Marines (10.5) GR-CY ... New
    6in1 Autodrive 1.99en-Anav4.50-GeoQ7.1- Recreational 3.01 CY- Bluechart 2008.5 Tides-Marines (10.5) GR-CY.....Latin ... New
    7in1 Autodrive 1.99el-NT 2011.30GR- Anav4.50-GeoQ7.1- Rec 3.01 CY- Bluechart 2008.5 Tides-Marines (10.5) GR-CY ... New
    7in1 Autodrive 1.99en-NT 2011.30GR- Anav4.50-GeoQ7.1- Rec 3.01 CY- Bluechart 2008.5 Tides-Marines (10.5) GR-CY.....Latin ... New
    Download:
    http://rapidshare.com/files/43695280...0_Unlocked.rar ... New
    http://rapidshare.com/files/43711528...ce_3D_3.01.rar
    http://rapidshare.com/files/43711529....rar.....Latin
    http://rapidshare.com/files/43712491....rar.....Latin
    http://rapidshare.com/files/42925697....rar.....Latin
    http://rapidshare.com/files/43625543...vasis_4.50.rar
    http://rapidshare.com/files/43624641....rar.....Latin
    http://rapidshare.com/files/43625531...es-Marines.rar
    http://rapidshare.com/files/43624637....rar.....Latin
    http://rapidshare.com/files/43712494....rar.....Latin
    http://rapidshare.com/files/43625534..._2008.5_GR.rar
    http://rapidshare.com/files/43624643....rar.....Latin
    http://rapidshare.com/files/43625529...08.5_GR-CY.rar
    http://rapidshare.com/files/43625537...08.5_GR-CY.rar
    http://rapidshare.com/files/43624638....rar.....Latin
    http://rapidshare.com/files/43787266...08.5_GR-CY.rar ... New
    http://rapidshare.com/files/43787262...08.5_GR-CY.rar ... New
    Only in 4in1 set with Greek characters the "Search all Cities" option doesn't work. All the other options in Search function works great.
    Auto Drive 1.99 With Modified Auto Drive Color Palette Final...New !!!
    Modified__________ Original
    Original Locked File With Greek Characters & Modified ADCP Color Palette
    http://rapidshare.com/files/44410907...or_Palette.rar
    Original Locked File With Latin Characters & Modified ADCP Color Palette
    http://rapidshare.com/files/44410911...or_Palette.rar
    Unlocked File With Greek Characters & Modified ADCP Color Palette
    http://rapidshare.com/files/44346334...or_Palette.rar
    Unlocked File With Latin Characters & Modified ADCP Color Palette
    http://rapidshare.com/files/44410910...or_Palette.rar
    Auto Drive 1.99 IMG Unlocked With Auto Drive Color Palette
    Greek
    http://rapidshare.com/files/43610113...P_Unlocked.rar
    Latin
    http://rapidshare.com/files/43610114...P_Unlocked.rar
    Auto Drive 1.99 IMG Unlocked With Garmin Color Palette
    Greek
    http://rapidshare.com/files/43610530...P_Unlocked.rar
    Latin
    http://rapidshare.com/files/43610452...P_Unlocked.rar
    For those who want to change color palette in MapSource version please change TYP file inside MapSource folder with the one you downloaded with the map file. You must always use TYP from IMG file having the same characters with MapSource file (Greek or Latin)
    Auto Drive Hellas 1.99 MapSource With Auto Drive Color Palette
    Greek
    http://rapidshare.com/files/43610978..._MapSource.rar
    Latin
    http://rapidshare.com/files/43610977..._MapSource.rar
    Important
    Owners of Garmin devices should be very careful using sets, first run must always be from SD/MicroSD Card NOT FROM INTERNAL MEMORY. Avoid using internal memory even after testing the set from your memory card and verifying is compatible & well working with your device. Big sets, 3in1 and higher, usually don't work with new Garmin devices there's no reason to use them anyway you can have all the maps you need in the "Map" folder.
    This sets are very useful in PNA, PDA & Symbian devices where you can increase the number of maps you can have to your memory card.
    Enjoy !!!
  2. The Following 17 Users Say Thank You to Santosan For This Useful Post:
    Santosan's Avatar
    52
    Re: Garmin GR & CY Maps In Sets (Auto Drive 1.99-Anavasi 4.50) & Auto Drive 1.99 Unlo
    First post updated with new sets for Greece & Cyprus
    Daci's Avatar
    Daci is offline Corporal
    Europe
    25
    Can you put the maps on other uploading site, becouse it gives me "error on page" message if I start the download and the page does not respond on any of my command.
    Thanks in advance!
    Santosan's Avatar
    52
    Quote Originally Posted by Daci View Post
    Thanks in advance!
    If you have a free account log out first and then try to download the file you want. All files working great the error probably has to do with "RapiPro expired" message.
    Santosan's Avatar
    52
    New sets 2in1, 6in1 & 7in1 have been added to the first post ...
    Merry Christmas & Happy New Year!!!
    Daci's Avatar
    Europe
    25
    Look what it shows: I dont know what to do. It keeps me giving the message "Error on page" and almost non of the buttons/commands doesnt work.
    Santosan's Avatar
    52
    Link is working OK, i'm using Firefox and i have Norton Internet Security 2010 for PC protection ...
    Santosan's Avatar
    52
    First post updated with four new Auto Drive IMG map files with modified original Auto Drive's color palette. Two Unlocked & two original locked files in Greek & Latin characters are available with the extra TYP files for those who want to change their MapSource version also.
  10. #9
    Santosan's Avatar
    52
    New files of Auto Drive Hellas in all versions with new modified color palette have been added to the first post.
