Results 1 to 7 of 7
Thread: Garmin GR/CY Maps In Sets (Auto Drive 1.99T- NT 2011.40 GR)
    Santosan's Avatar
    Santosan is offline Sergeant
    52
    These sets contain full road/off road network and nautical maps for both countries. All sets are fully unlocked, no need for unl file, just copy the set into Garmin folder. In these sets you can find the new version of Autodrive 1.99T & NT 2011.40GR. Tested and working: PNA, PDA, Garmin Mobile PC & S60.
    Only in 4in1 set with Greek characters the "Search all Cities" option doesn't work. All the other options in Search function works great.
    Available Sets Greek/Latin
    2in1 Autodrive 1.99T el - Anavasis 4.50 GR
    2in1 Autodrive 1.99T en - Anavasis 4.50 GR.....Latin
    3in1 Autodrive 1.99T el-Greek Anavasis 4.50 - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR
    3in1 Autodrive 1.99T en-Greek Anavasis 4.50 - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR.....Latin
    4in1 Autodrive 1.99T el - NT2011.40GR - Anavasis 4.50 - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR
    4in1 Autodrive 1.99T en - NT2011.40GR - Anavasis 4.50 - Bluechart Atlantic 2008.5 Tides-Marines (10.5) GR.....Latin
    6in1 Autodrive 1.99T el-Anav4.50-GeoQ7.1- Recreational 3.01 CY- Bluechart 2008.5 Tides-Marines (10.5) GR-CY
    6in1 Autodrive 1.99T en-Anav4.50-GeoQ7.1- Recreational 3.01 CY- Bluechart 2008.5 Tides-Marines (10.5) GR-CY.....Latin
    7in1 Autodrive 1.99T el-NT 2011.40GR- Anav4.50-GeoQ7.1- Rec 3.01 CY- Bluechart 2008.5 Tides-Marines (10.5) GR-CY
    7in1 Autodrive 1.99T en-NT 2011.40GR- Anav4.50-GeoQ7.1- Rec 3.01 CY- Bluechart 2008.5 Tides-Marines (10.5) GR-CY.....Latin
    Download:
    http://rapidshare.com/files/45338732...T2011.40GR.rar
    http://rapidshare.com/files/45338992...T2011.40GR.rar
    http://rapidshare.com/files/45338731...T2011.40GR.rar
    http://rapidshare.com/files/45338987...T2011.40GR.rar
    http://rapidshare.com/files/45338727...T2011.40GR.rar
    http://rapidshare.com/files/45338986...T2011.40GR.rar
    http://rapidshare.com/files/45338728...T2011.40GR.rar
    http://rapidshare.com/files/45338989...T2011.40GR.rar
    http://rapidshare.com/files/45338788...T2011.40GR.rar
    Pass: Santosan
    Important
    Owners of Garmin devices should be very careful using sets, first run must always be from SD/MicroSD Card NOT FROM INTERNAL MEMORY. Avoid using internal memory even after testing the set from your memory card and verifying is compatible & well working with your device. Big sets, 3in1 and higher, usually don't work with new Garmin devices there's no reason to use them anyway you can have all the maps you need in the "Map" folder.
    This sets are very useful in PNA, PDA & Symbian devices where you can increase the number of maps you can have to your memory card.
    Enjoy !!!
  2. The Following 8 Users Say Thank You to Santosan For This Useful Post:
    Re: Garmin GR/CY Maps In Sets (Auto Drive 1.99T- NT 2011.40 GR)
    all offline my friend if you can reupload thanks
    Santosan's Avatar
    52
    Links checked, they're working great !!!
    nasisss is offline Private
    thanks!!!!!!!!!!!!!
    zaxaroplastis is offline Lance Corporal
    Feb 2011
    Passw of the links?
    Santosan's Avatar
    52
    You can find Pass bellow the links
    e-gsmshop is offline Lance Corporal
    Apr 2011
    27
    Many Thanks
    e-gsmshop
  1. 20th March 2011, 22:21
