Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree2Likes
Thread: Edge 800/810
    Edge 800/810
    GARMIN EDGE 800 need Help to install unlocked maps.
    Getting message "can not authenticate the map". All maps (MapSource) are unlocked by JM 1.5 unlocker based on unit ID and perfectly working on other Garmin GPS devices nuvii 260 and Edge 705. Also, ive tried to installed alternatively unlocked maps ( unlocked with Unblock MapSource Directory v1.4) - no success ether, same error message.
    Does anyone who owes EDGE 800 is experiencing the same issue? Is it crackable?
    MapSource 6.16.3 patched
    CTENT2011.30
    CTNANT2011.20
    raduss and albertweber like this.
    Kor@l's Avatar
    Kor@l is offline Global Moderator
    1,975
    356
    Re: GARMIN EDGE 800 need Help to install unlocked maps.
    Did you use Garmin alternativ unlock v5.63, it can help you........ i hope
    @l
    Many thanks Kor@l works like a charm!!!!!!!!!!!!!!
    dani_bv is offline Private
    Feb 2011
    hey guys , i am new here ...
    where can i find the europe maps for bike on this forum for model garmin edge 800
    thks!!!
    Kor@l's Avatar
    1,975
    356
    In THIS post
    Jul 2011
    turn by turn navi AND Topo map?? - edge 800
    Hi Garmin pro's :-)
    I have just bought a edge 800 incl. euro card on SD card
    I just got the unlocked TOPO Danmark v.2 card, i can load it to my extra Micro SD card, works Perfect.
    How do i get both cards to work at the same time? - i want both turn by turn navi and topografic map :-)
    //aarosin
    Sep 2011
    Transporting maps to an Garmin Edge 800
    I cant transport maps to a garmin edge 800. I get the message "couldn't open idex file :C\Garmin\FAM_1725\product.mdx
    Who knows wat to do
    B. Ommelles
    west_midlands is offline Private
    Mar 2012
    garmin 800 follow course purple line change
    Hi
    has anyone managed to change the course follow purple line to another colour on a garim edge 800
    Cheers
    Apr 2012
    Netherlands, Hilversum
    Re: garmin 800 follow course purple line change
    Yes, that is what I'm looking for as well, because I'm color blind, so I prefer I.e Yellow
    May 2012
    applying Edge 800(J) firmware to Edge 800(U)
    I have Edge800(U), and I would like to apply firmware of Edge800 Japanese version to it.
    Normal way, copying GUPDATE.GCD into garmin dir, it's ignored beacuse of the difference of HW_ID.
    So, I changed HW_ID by RGN_Tool.
    It's ok until updating software, but after boot, stop with err msg "SYSTEM SOFTWARE MISSING". (I get back by RGN)
    I think it checking Unit ID, but I can't find the address.
    Anyone can apply Japanese firmware?
    <info.>
    Edge 800 has 3 variations for customizing each language.
    1. Edge800(U).
    English(Universal) version, which support many language including English. But Japanese, Taiwanese, Chinese can't show & input.
    Garmin: Edge 800 Updates & Downloads
    http://www.garmin.com/software/Edge800_240.gcd
    HWID=1169
    Unit ID=38162xxxxx
    2. Edge800(TW).
    Taiwanese & Chinese version.
    Garmin - 衛星導航 ‧ 全球第一 | 產品資訊 | 戶外休閒 | Edge 800
    http://download.garmin.com/tw/downlo...0_TWN_2.50.exe
    HWID=1333
    Unit ID=?
    3. Edge800(J).
    Japanese version.
    Bicycle Edge800JUpdate&Download
    http://www.iiyo.net/support/download/edge800j_260.zip
    HWID=1334
    Unit ID=38261xxxxx
